Question about Kenmore Dishwashers
I am getting an F4E1 error code on my Kenmore Elite 665.13963K017. What does this code mean and how do I fix it? This code started after reattaching a loose drain pump hose.
The first problem was an E2C2 code. I found the drain pump hose hanging off the tub. Reattached it and still had the code E2C2. Let the dishwasher dry out for a couple days and the unit started working. A couple weeks later the drain hose worked its way off the tub stem again. This time I attached it with a better clamp. When I reconnected the unit, the code F4E1 showed in the display. I can't get it to restart. I was sure to remove as much water from the dishwasher before working on it to avoid any water from getting on the electrical connections
SOURCE: Will not drain and shows E6 error code
I had this problem and eventually found a small piece of mussel shell in the bottom part of the machine, it seems they are very sensitive to the tiniest fragment of debris.
Posted on Jul 14, 2007
SOURCE: error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Posted on Dec 29, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Error code F4E1 need reset
Turn off the power to the dishwasher for about 5 minutes before you power it up check that the water supply line is on. Also check for restricted drain area. Power it up and clear the power fail fault see if it works
Feb 24, 2014 | Kenmore 24" Built-In Dishwasher, Stainless...
Dishwasher f4e1
This is an error that means the controller is not talking to the motor. You need to check the connections on the motor
Feb 09, 2014 | Kenmore 665
CODE F4E1 will not go away
This error means that the controller cannot communicate with the motor. It is possible that something came loose when you replaced the clamp. Recheck all the connections .
Feb 09, 2014 | Kenmore 15322 / 15324 / 15329 Built-in...
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
187 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
