Question about Kenmore Refrigerators
Refrigerator side is not maintaining temperature
The refrigerator side of the unit is not kepping the temp at 37degrees. It is at 50. The freezer is fine. I have had this problem in the past almost annually and have fixed it by turning the unit off and on again(as the manual says). I normally have to do this several times but this time I can't get it to work.
    Guru:
  • 1,524 Answers
You have a defrost problem. Sounds like the ADC is going.
Posted on May 20, 2009
What is freezer and refrigerator temperature suppose to be set on
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Jenn-Air JSD2789GES Side by Side...
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Refrigerator will not maintain proper temperature
Check in the back of the fridge section; there is normally a control that is provided for 'balancing' the cold air between the two sections. That coolled air is distributed by a concealed fan that may not be running; you should be able to ear or feel the air movement when the unit is in a cooling cycle.
Apr 19, 2009 | Samsung RS2534 Side by Side Refrigerator
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Refrgerator side gets to cold
Possible bad thermister or temp sensor. Part # wr55x10025. Your unit is a dual evaporator system. So fresh food side is independent from freezer. That would be the most likely cause. It retails for $14.00 from ge parts online. Good luck.
Aug 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
