Looking for info on GE WLRE4500GOWW mode Washing machine. Making very loud grinding noise when drum is moving back and forth. Maybe bad bearing?
  • Anonymous May 20, 2009
    GE Model # WLRE4500GOWW
    I have removed the front of my washer and can see that the tub appears to have sunk and the metal pulley that the belt is on is grinding on the bottom of the machine.
  • golinveaux May 21, 2009
    I do not understand how a bearing has caused the entire tub and attachments to sink low enough to grind on the bottom of the washer while agitating. Everything works perfectly...is there anot a way to adjust the tuba nd attachments back up an inch so it will not rub?
  • 90 Answers
Certainly sounds like main bearing is siezing. Best of luck.
Posted on May 20, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Replace water pump on frigidaire affinity
Plug off the wall. Open the door, keep your thumb at the opening and move the drum towards you and to the back of machine. If you hear some clicking or vibration, your bearings have shot. YouTube makes it easy to change.
Pl click if helped.
Mar 28, 2013 | Frigidaire Washing Machines
My maytag hav2558aww wont turn on wash cycle
Possible that the grinding noise comes from the drum, irregular movement or broken paddles.
You can try and attempt only if equipped with a fundamental understanding of the working .
I shall give you some tips to this click 1..: Washing Machine
2. Replacing bearings
Jan 24, 2013 | Maytag HAV2558 Top Load Washer
Making a loud grinding noise when agitating
The bearing in the drum is bad,usually the whole drum has to be replaced,bearing is made not to be replaced,on my Maytag,it happened,luckily I had a warranty,drum was 700.00.
Oct 23, 2012 | Washing Machines
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
My washing machine started to make a loud grinding noise and does not rotate to wash nor to spin. after moving the machine i found some plastic shavings under it.
Sounds like the bearings for the drum have or are on the way out. The belt has probably broke or come off.
Depending on the age, cost of new and personal feelings it can be repaired but normally it isn't cost effective, unless the machine cost £500+ ($800+)
Jun 14, 2009 | Washing Machines
GE Washer Tub has sunk and is grinding on bottom
I had the same problem and as near as I can tell, we ran a load the was simply too big and the upper chasis "droooped" just enough from the weight to cause the metal to bow. As a result, the bottom of the tub assembly was rubbing against the lower metal chasis, creating a loud grinding noise. Metal filings indicated the wear point. I took a piece of wood that is about 1"x3x height and wedged it in front and slightly to the left of the motor, running straight, up and down. the board stands straight to take out the bowing- lifting the tub about 1/4" more. This was just enough to provide the clearance needed to prevent grinding. If the vertival board is too long, you won't be able to get the front cover back on.
May 20, 2009 | GE Washing Machines
Washing Machines Logo
310 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
