Question about Quantum SDLT 320 External LVD (000003616772) Super DLT Tape Drive
During extracting files from DLT tape to the local disc it gives input/output errors
Durning extracting files from DLT tape to local disk it gives input/output errors.
    Scholar:
  • 81 Answers
Go to driver dectective and check to make sure your drivers are up to date.
Posted on May 20, 2009
Hard disk input output error
This sounds more like an issue with your hard disk than the tape drive.
Have you tried the tape drive on another machine to see if it works better from a different backup source?
Nov 08, 2013 | Seagate STD2401LWS Segate 20/40gb Dat Dds4...
Dlt-v4, the drive accepts the tape only to spit it out
You have to try the other tape if the same problem you have to replace the head.
Feb 05, 2010 | Quantum DLT-V4 DLT Tape Drive
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
On power up we get an 'E' during drive initialization
E stands for error (Although i am sure you could have guessed this)
Try to see if the drive at the back is passing self test or not so we know if it is a drive or loader issue
If it looks as if the drive is OK try cleaning the tape slots as there are sensors to sense tape loaded etc
Is the arm (and the main chassis) bent? this will also cause issues.
If it is a drive issue (Drive fails POST) then it is most likely a tape leader issue where the drives needs to be removed and the leader refitted (see other posts on here about DLT tape leader issues)
Aug 10, 2009 | ADIC FastStor DLT7000 DLT Tape Drive
Parity error issue with TF85 DSSI based on VAX4000 - 700
If cleaning the heads using the cleaning tape did not help, then there are 3 possibilities that I know of:
1) The heads are sufficiently dirty to require direct cleaning with a more powerful solution.
2) The heads are defective.
3) The heads are out of alignment.
Parity errors are not usually controller problems. If the head alignment has drifted enough, you may be missing a track when recording. An initialization includes writing format information at the beginning of the tape. This is "re-read" during the process to confirm correct writing. This is the part that is failing.
Keep me posted.
Dan
Feb 20, 2009 | Compaq DLT Tape Drive (TF85) DLT Tape...
I dont know how to install external tape drive compaq DLT VS 80 in Red hat 4
Hello,.
Please reboot your server and attach tape drive... if it is still not detecting please check the
#dmesg
command to check the error...
and get back ............
Dec 02, 2008 | HP (154872-003) (154872003) DLT Tape Drive
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
/dev/st0: Cannot open: Input/output error
Just the fact that /dev/st0 exists indicates that the OS sees the tape drive. When you say you are "moving the data to tape drive" just how are you doing this? Have you read the dump man page?
Jan 25, 2008 | HP C7438A (Refurbished) DAT Tape Drive
Quantum SDLT 320 External LVD (000003616772) Super DLT Tape Drive Logo
139 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
