VCR problem Problem is with the VCR. When I playback a tape the picture flickers up like the vertical hold is gone. I tried manually cleaning it and have also tried adjusting the tracking. Both did not improve it. What could the problem be?
  • BARBIE542 Aug 07, 2008
    Emerson video cassette recorder model EWV404.
    ON play back, picture keeps flipping. Problem says ajust tracking by pressing CHANNEL button. This does not work. No separate button for just tracking flipping problem.
    When I fast fwd ,picture does not flip, when I play I get the same flipping, also sound can be effected.
Auto progam channels
Posted on Jun 08, 2011
It is likely the drive belt located on the underside of the carriage. Remove the top, then look for about 4 or 5 screws holding the carraige in place. Disconnect a couple ribbon cables and remove the whole carriage. Look under the carriage and you'll see the belt in question. It's probably slipping which causes the picture to roll. Occasionally you can get away with cleaning the belt with a rubber cleaner... more likely you'll need to replace the belt (which cleaning only delays).
I doubt very much if the alignment is off - that only usually happens if you've been poking around in there in force. While you have the top off give the thing a good clean. Ideally you'll demagnitize the heads and the audio/record heads. Just follow where the tape runs when in play mode and clean all the surfaces with a cue tip and alchohol. Rub clean when done to ensure all the residue is removed. When cleaning the head itself - be very careful. Rub the Qtip gently along the length of the pick-up head - DO NOT RUB UP AND DOWN, rub along. Rubbing up and down will break the ferrite head which will render the VCR trash.
Try not to touch the belt with your fingers as that will leave oils on the belt and speed the breakdown process.
Posted on Jan 04, 2009
  • 51 Answers
The problem is most likely with the tape path guides being out of alignment or in need of cleaning.
It could be worn or dirty video heads/drum.
It could be a worn pinch roller.
It's in need of at least a professional cleaning, possibly a tape path alignment and possibly some rubber drive parts needing to be replaced.
My guess is a tape path cleaning/alignment along with a pinch roller replacement.
You may want to consider this an opportunity to move from tape to DVD. The home DVD recorders are very cheap now and will do the same thing your VCR does, only better.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Posted on Oct 18, 2007
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
Oct 29, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR Tape jumps like the vertical hold is off.
Most VCRs use the channel Up and Down buttons for the tracking
Jun 30, 2009 | Panasonic PV-9662 VCR
My jvc hr-s8700 has no hifi stereo playback
The VCR stereo playback sound is only available through the AV/SCART connection and will not work through the coaxial antenna cable.
Jan 08, 2009 | Televison & Video
CCD-TR705e Sony video recorder hi 8 playback 3 beams
the camcorder flickers when viewing playback - pictures flickering
Dec 10, 2008 | Pure Digital Point and Shoot Video...
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Nov 30, 2008 | GoVideo VR4940 DVD Player/VCR
Flicker on playback
Could be tracking, dirty / faulty heads, or mis-alligned guide rollers.
First,adjust the tracking on the player during playback. This is done by pressing P+ or P- on the remote control.
If this doesn't work, use a video head cleaner. This consists of a video cassette and fluid. Follow the instructions with the cleaner.
If this still doesn't help, and you are confident in opening up the VR550, you could cleaner the heads manually.
Disconnect from the mains.
Remove the screws from the back and sides of the VCR.
Gently ease the lid off the machine.
Locate the large silver coloured head drum towards the back of the machine. There are four small receptors around the side of the drum. These are the video heads.
Take a small piece of clean white paper about 1.5 inches square. (Copier paper)
Hold the paper square over 1 finger and rub each head in turn. Keep the head near the centre of the paper so as not to catch the heads with the edges of the paper.
Check the paper for dirt from the heads.
Reconnect the player and try a tape. If the problem is still there, try cleaning again.
If none of this works, insert a tape NOT recorded on this machine (Mis-alligned rollers affect recording as well as playback) and play. Locate the rollers which guide the tape around the mechanism. Particulary either side of the head drum.
The rollers have adjustments on the top, which can be turned to move the guide up and down slightly. This is a fiddly job, and over adjustment could cause the tape edge to be damaged.
Adjust the rollers to get a clear picture. It is mainly trial and error.
If all fails then the video is probably destined for the skip.
If you need a replacement, , will sell you a VR550 at a very good price.
Apr 09, 2008 | Philips VR550 VHS VCR
Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Dec 28, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Televison & Video Logo
398 people viewed this question
Top Televison & Video Experts
