Question about Roper RGX4634KQ Gas Dryer
No longer drying the clothes. How can I fix this?
I have a Roper gas dryer, model RGX4634KQ1 and it is not longer drying the cloths, what can I do to fix it?
  • 864 Answers
Make sure the lint filter is clean and the dryer vent pipe is not clogged all the way to the outlet.
If it is not getting warm the gas igniter/glow plug may need to be replaced.
If the igniter is OK but the flame does not light the gas valve coil may need to be replaced.
If it gets warm and the venting is not clogged, the thermostat or flame sensor may need to be replaced.
Posted on May 20, 2009
Roper dryer not dry clothes well
leave them in longer then or check washer it might not be spinning them dry enough to begin with
May 20, 2014 | Roper Dryers
My gas dryer the heat cycles on & off
clothes not drying, but dryer runs & heats?
1.defective thermostat-----replace
2.fan or it's pully loose on shaft----tighten set screw
3.incorrect heat or timer setting---reset timer
4.clothes to wet to when placed in machine
5.clogged lint screen or duct---clean out
Jul 29, 2010 | Roper RGS7646KQ Gas Dryer
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
The dryer wont dry the clothes thouroughly. theres heat but not enough to dry the clothes
you need chek are clean:
1-screen.
2-line chute assembly.
3-housing blower.
4-pipe duct.
Oct 05, 2009 | Roper RGX4634KQ Gas Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer not drying cloths
http://www.pcappliancerepair.com/model-display.php This shows the screws (#2) that hold the front on. Use a putty knife to push on spring catches (#20) to release the top.
Jan 24, 2009 | Roper RGX4634KQ Gas Dryer
Roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
Sep 04, 2008 | Roper REX4634KQ Electric Dryer
Needs 2 drying cycles
I am assuming you are cleaning the lint filter. Check the vent pipe out the back. If it vents into the wall, the piping leading to outside may be plugged. Your washer is spinning the clothes good, right? If the clothes are excessively wet they will take longer to dry also. If its practical, remove the vent hose and let it dry blowing into the room. It may suck but just once for a test.
Mar 06, 2008 | Roper REX4634KQ Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
178 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
