I HAVE A DIPLOMAT hja 8552 WASHING MACHINE THAT LEAVES DIRTY MARKS ON CLOTHES AND IS NOT SPINNING
The machine is around 6 years old and has a lot of use. I started to notice dirty greasy oily marks on clothes and it doesn't always complete a spin cycle, however the door lock does release so there is no residual water left in the drum. I have cleaned the door rubber and am in the process of locating the filter (which for an integrated washing machine is in a ridiculous place!) Any ideas what the problem could be? Both problems have been gradually worsening to the point of now rendering the machine unusable.
gittos73
  • 244 Answers
SOURCE: dirty washing
what this could be is your bearings check if there is any amount of movement from the drum by opening the door place your palm onto the front of the washer so its on the bodypart of the washer now place your fingers into the washer facing down so you can grab the drum with them now pull up and if there is any movement then its confirmed bearings need replacing m8 get the warranty company out its a big job some companys just replace the washer m8.It will be the bearings though what those black marks are is the grease out of the bearings cause the seal has gone ive done hundreds of bearing jobs let me know how u go on m8
Posted on Jan 24, 2008
SOURCE: Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Posted on Sep 05, 2008
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
Hi I am needing a manual for a intergrated washing machine code no HJA 8552 is there any way I can down load
Try
manualslib.com
They have quite a wide range of manuals.
At the site, select your make & model or type it in the search bar.
Dec 19, 2017 | Washing Machines
I have a fisher&paykel washing machine every time l wash my clothes it leaves Dirty marks on my clothes I have pulled out the barrel and cleaned it and put it back together and it still leaves marks
With no clothes in the machine, Do a long hot wash, add some bleach, stop using fabric softener. Cut down on soap usage. This should clean out the machine. If it happens again, there may be a mechanical problem which is allowing grease or oil into the machine.
Mar 20, 2017 | Fisher and Paykel Washing Machines
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Ken more washer leaves dirty marks on clothes
Pull the agitator out and clean the inside of it and the area of the tub that it covers. A buildup of crud won't be removed by simply washing out the machine. Rinsing out a frying pan will get a lot of the dirt out but, it must be properly washed to get it all.
Jan 20, 2013 | Washing Machines
What does A.C.P mean on my LG Direct Drive 5 washing machine?
In a French speaking country, it means "Arret cuve pleine"
Jul 27, 2011 | LG Washing Machines
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
Last load of washing has lots of black dirty marks on them
It would appear that the drum seal and bearings have failed. If you have been doing constant cold water washing and using fabric softener and the machine is over 5 years old, I would say its time for a new machine. There are not many that last past 5 years any more especially with cold water and fabric softener usage. Bearing and seal replacement can be very expensive. The drum shaft (Spider assembly) will probably need changing as well.
Dec 21, 2017 | Zanussi FLA1101W Front Load Washer
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Load Washer
there is a drive belt from motor to drum but unlikely it needs tightening but possible. possibly a motor fault - try to identify where the smell comess from
Mar 20, 2007 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
