Question about Panasonic Toughbook 28 Notebook
Laptop colors on monitor not right-red is pinkish, blue is teal
The colors are not correct on my lcd latop monitor. When plugged into an external monitor the colors are perfect. Red is pinkish, blue is teal, bright green is lt. green, etc. The hue, sat., and lum of the "teal" appearing color matches the setting for the "blue" and all of the others are correct also.
    Scholar:
  • 81 Answers
When running additional application you need to be plugged in to a 115v power supply, laptops dont do well with alot of things if they are not plugged in.
The other thing is check you memory, you may not have enough memory to run that much program. If you have plenty of memory, it may be you video card doesnt, it so you may be able to go into your BIOS and dedicate some of your main memory to the video card.
Thirdly check you drivers to see that they are up to date.
Posted on May 20, 2009
    Master:
    Sergeant:
  • 461 Answers
Take it back to the customer service for the LCD to be changed
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Hi, My monitor will once in awhile go from the warm white color to a slightly red or pinkish color. The monitor is about 5 years old and the model # is AL1913. Any thoughts? Thanks. Don
Red or pinkish cast on the whole screen? You may want to check the VGA connectors and pins at both ends. Also try it with anothe PC to make sure it is not video problem in the PC.
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Dec 15, 2010 | Acer AL1913 19" LCD Monitor
Asus laptop and red shadows on letters and bad picture. is this a lcd inverter problem? External monitor works ok.I check lcd panel cable and replace lcd panel but all same
Yep, it's the inverter. Anytime there is a red or pinkish tint or hue you know it is the inverter. Usually the inverter is very easy to change. I would buy one on eBay for your best price...
Good luck!! EJ Kudelka
Oct 18, 2010 | Computers & Internet
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Jun 24, 2009 | Acer X193W LCD Monitor
Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Open Questions:
Panasonic Toughbook 28 Notebook Logo
276 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
