Question about GE Spacemaker JVM1640SJ Microwave Oven
Olive Oil- Microwave Broken
My mom put olive oil in the microwave (Whirlpool MW 201) trying to heat the oil. There was a big explosion and the microwave stopped working immediately with an error message on the LED display. The store says that this could be fixed for €60 but that a replacement can be bought for €80, so they say we might aswell buy a new one.
Can I fix this myself? Anyone able to help?
Thanks,
Killo
  • 90 Answers
You can only do as your store reccomends. Buy a new one do not mess with microwave ovens.
Posted on May 20, 2009
  • 57 Answers
Can u fix it urself..? depends on ur expertise..ne ways ...not adviced to do DIY on this kind of equipment...for better help try ....http://www.repairclinic.com
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
Sep 02, 2014 | Whirlpool Microwave Ovens
Microwave slow heating
It will need a magnetron and maybe a large capacitor soon
Nov 29, 2013 | Microwave Ovens
How to fix microwave with bang, flash
That was the magnetron tube breaking. Too expensive to fix. Better to go and buy a new microwave.
Feb 04, 2013 | DeLonghi MW 535 Microwave Oven
It is making different kind of noise and won't generate heat.
Most often with MW's the Magnetron fails that as well as the high Voltage Diode. MW's are NOT to be trifled with they are lethal to service and MUST be done by an experienced professional.
The best thing to do is contact Whirlpool, and ask for a referral to an authorised service center, make contact here and when face to face first only ask for a "Quote" as to costings and go from there.
Sep 10, 2011 | Whirlpool GH7155XHS Microwave Oven
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
Display on my westinghouse microwave says CHIL it wont work now
hello,
what you are to do to fix up the problem is that,put iff the the oven for some time and allow it to relax it self with out an operation, then put it on again then if it has time programming or reset button then click on an of this button for it to restart it self ,
but if this problem remain then you will have to open the the oven then trace the wire down to the panel to clean up any from of dirt or liquid around the panel then couple it back at it was with this the problem will be solve.
thank you and thanks for using fixya.
Jun 14, 2010 | Westinghouse WST3504 Microwave Oven
Can you use a microwave if the glass on the door is broken?
It is not advisable. The door is a critical safety part of the microwave oven. The glass being gone will allow heat in areas of the door not designed for heat. The glass also is a support for the safety mesh that contains the microwave energy to the cavity.
May 12, 2010 | Westpoint TV-201 Microwave Oven
As the microwave is on and the plate inside turns, we hear a creaking noise how can i fix this? wd40 or other?
do not use WD-40. use cooking oil instead (olive or corn, or canola, it doesn't matter)
Oct 21, 2009 | Microwave Ovens
Microwave turntable
The solution is very simple. Unplug the microwave first. Remove the round dish. Remove the circular riing with the rollers and set aside with the dish. Carefully with a butter knife, pry up the coupler and set aside. Examine to make sure it isn't broken or cracked where it slips over the motor shaft. Remove 5 Phillip head screws from the bottom pan and it hinges down out of the way exposing the motor. Remove 2 screws holding the motor, slip off the plastic dual flat connector and slip back onto a new motor $52.25 + shipping from GE parts. Remember your actual MW Model number is NOT XL-1800 but it is on a metal tag inside the MW on the left side. Put the motor screw in as removed so the shaft is free to stick up the hole in the bottom of the MW. Put the pan screws back up, put the coupler on, the ring in and then the dish and line the slots of the dish up with the star coupler so it catches. Turn on MW, touch the turntable button and make sure it is "ON" and not "OFF" and it should be, with the door shut, turning like a quiet little top as new.
Aug 19, 2008 | Microwave Ovens
Microwave operates but does not heat
The High Power Transformer (Magnetron) fuse is wrong. Replace it. It will work perfect... The fuse is always hidden in a plastic case fixed at the bottom of the microwave near the big capacitor... My email: neo@intnet.mu
Aug 19, 2007 | Westpoint TV-201 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
473 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
