Question about Microsoft Premium System for Xbox 360
Ghost vision i have got my xbox running through the component leads into a hd tv tried everything but cannot get rid of ghost vision please help
  • 60 Answers
Wel if the ghost vision is still there try and set the brightness and contrast from your xbox 360 console
Posted on Jul 18, 2009
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Nov 20, 2015 | Sanyo DS31590 31" TV
Ghost picture (faint double image)
It sounds as if your optical lens are out of alignment on your tv..
Sep 30, 2015 | Hitachi 50V500 50 in. HD-Ready LCD...
I can not get my component video to work for my xbox 360 with my with my Toshiba 36A43 Television
Do you get picture at all? What is your resolution setting on the Xbox? That TV is Standard Def. Plus on the plug that goes into the Xbox there is a switch for HD and non. Check and see if its swtiched over to HD. If the Xbox is trying to run in high def on a standard tv you will get no picture. Especially using the the little switch on those component cables. Hope this helps!!
PS...If this does help you please rate my level of help...Have a good day and good luck =)
Apr 23, 2011 | Televison & Video
Ghosting of images when in hd
Well, seems like your video system is error, need to reset. with qualified personnel you can fix this problem with low cost.
Dec 09, 2009 | Cell Phones
Unreadable text
I do not believe there is a solution. I had the same setup and could not read the text. I tried everything and eventually got rid of the 360 because without an HD TV, I could not read anything.
May 31, 2009 | Microsoft Xbox 360 Console
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
HDTV Problem
there shouldnt be a problem with the cable, if you use the component leads then you will not need to use the s video cable for video incase that is what you are doing, component only uses 5 connectors and the switch should be set at HDTV not tv and the tv set at component Use the following colours into your tv:- Green, Blue, Red and the audio red and white, you do not need the yellow or the s video plugs. Then select the 1080i when in the component setings on your tv and do the same in the dashboard settings
Jul 01, 2007 | Microsoft Xbox 360 Console
Microsoft Premium System  for Xbox 360 Logo
71 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
