F72 error code kenmore elite oasis washer - Washing Machines
SOURCE: for the kenmore elite oasis
We jamed a straw in the door lock so the sensor thinks there is something in there
Posted on Jul 03, 2008
SOURCE: kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Posted on Jun 09, 2009
jan mczeal
  • 632 Answers
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Posted on Jan 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hello, I have a
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
retracting.
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
