Question about HP PhotoSmart C4280 Laser Printer
Schematic wanted for a HP #0957 2231 power adapter.
I need a sachematic for a HP power adaptor #0957 2231 as used on a HP C4280 printer to repair it locally.
SOURCE: Printer PS C4280 All-in-One Won't install to HP Pavilion BT938?
i cant install the sofweart
Posted on Dec 14, 2007
  • 105 Answers
SOURCE: Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Posted on Jun 20, 2008
professor_sc
  • 180 Answers
SOURCE: No power to printer (HP
Buy directly from HP to get the correct power cord. Their number is 1-800-474-6836
Posted on Aug 11, 2008
  • 23 Answers
SOURCE: How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Posted on Feb 17, 2009
SOURCE: Install new color caridge on C4280 HP printer
open your printer cover and you can easily install your caridges
Posted on Aug 30, 2009
Is there any way to install my hp photosmart C4280 without the disk? I recently moved and can't find it. The conncetion point on the actual printer is damaged as well, so I can't simply connect it...
hello Jessica
kindly send me 4 thumbs up
you simply go to this site , select the OS you use and download the drivers for the printer, save on your desktop. make sure the printer is disconnected from your computer . install the drivers after they are downloaded and follow instructions-- very qick and easy
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&lang=en&lc=en&product=3192753&
Aug 15, 2011 | HP PhotoSmart C4280 Laser Printer
No power HP DeskJet F380 All-In-One Printer
Hi thorchop1,
There are two things that might cause for your HP Printer to get no power at all. First, the power adapter. You may want to try using other power adapter compatible to your system. If using other power adapter works you can buy a new power adapter for your printer. Another thing is, the power supply. If after changing the power adapter and still system will not turn on then you have a bad power supply that needs to be serviced by local repair man or technician from HP.
Hope it helps.
Thank you for using FixYa.
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
What name of ac adapter interface?
Its Hewlett Packard Printer AC Adapter (0950-4404) -6196 Power Adaptor
Jul 11, 2010 | HP Deskjet D2430 Printer
Need to replace power cord for Photosmart C4280 All in One
Sure, you can find it on amazon for best price,click here and take a look Amazon com Photosmart C4280 power cord. I hope this was helpful. Cheers
Feb 10, 2009 | HP PhotoSmart C4280 Laser Printer
No power
it's yr logic card problem. called power wich is placed in printer i need to repair..
Jan 08, 2009 | HP DeskJet 3745 Printer
Have Vista,
the software may need to be reinstalled.
Nov 11, 2008 | HP Photosmart C4280 All-in-One InkJet...
Printer cable
If you use an universal power adapter, you must use one that can provide voltage of at least 30V (25V will work, but better using proper one).
Your 12V adaptor is not enough to power this printer. Buy the proper 31V power adapter.
The replacement costs $12 on Ebay (click).
Or $16 from retailer.
Sep 26, 2008 | HP OfficeJet 7310 All-In-One InkJet...
How do i find the serial number for my HP Photosmart c4280 all in one printer
hi ,
if u want serial no of u r printer please check back of the printer or bottum of the printer there is some barcode is printed with
number like
if this information is useful for u please rate me.....
Jun 14, 2008 | HP Photosmart C4280 Aio Printer
Printer is not working.
You can first try to connect the unit to a different wall jack , if the adaptor is not warming up after a few minutes , its a concern with the power adaptor .
U can call Hp parts store to get the adaptor.however u need to give them the part number (which will be located on the adaptor itself )
Parts Store Number - 1-800-227-8164.
Thanks.
May 16, 2008 | HP DeskJet F380 All-In-One Printer
Power failuer
First off it?s a fairly risky proposition to plug a power adaptor from one device into another without making absolutely sure it supplies the correct voltage, amperage and has the correct polarity. Your laptop needs 18.5 volts, 3.5 amps, and approximately 65 watts to charge the battery. If you power adaptor is less that 3.5 amps it will shut down to prevent any damage so that?s probably what is happening. I would suggest going to the HP (now owns Compaq) or Ebay web sites and purchasing a replacement there.
Jul 24, 2007 | Compaq Evo N610C Notebook
HP PhotoSmart C4280 Laser Printer Logo
496 people viewed this question
Seeker5211
Seeker5211
