Question about Retail Supplies
Skybox f5s stuck in load up - Retail Supplies
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
How can i pay a subscription my sky box f5s?
http://www.digital-kaos.co.uk/forums/f184/skybox-f5-sky-subscriber-general-query-335872/
Jun 11, 2014 | Retail Supplies
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox stays at 50 degrees all the time
The SkyBox was built for Maytag by a company in China. Production stoppedabout 2 1/2 years ago, and Maytag purchased ALL available service parts available at that time. As inventories are depleted, there will be no more parts available.
An issue with the SkyBox involved a build up of frost and ice on the evaporator plate built into the wall behind the dispensor assembly. This build up insulated the product from the evaporator coil. It also caused the circulation fan to stop running. Unplug the unit and leave the door open for 24 hours. Plug it back in, set the thermostat indicator at the 11:00 position and close the door. See if this brings the temps back down to the 36 to 42 degree range, I hope this helps.
Jan 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Retail Supplies Logo
112 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Are you a Retail Supply Expert? Answer questions, earn points and help others
