Where is the serial number on Pulsar PG7500 generator?
I have a ladies pulsar watch V220-5550 RO Serial number 600619. When was it made and what is the battery ID needed for it?
Just take it to a local jeweler. They have all the batteries and the tools to remove the back. The cost is $8 to $15 and done while you wait.
May 13, 2018 | Pulsar Watches
Woman's Pulsar watch battery # for serial number 252100.
looking at the movement that is fitted its likely to have an SR621 silver oxide battery.
Jan 07, 2018 | Pulsar Watches
Oil capacity for 6000w pulsar generator
What is the full model number? We can tell you then. :)
Jan 01, 2017 | Electrical Supplies
What is the recommended oil capacitiy for a pulsar 6000w generator
This unit show to have a 10HP gas engine and thus should have a dip stick where you add oil. Guess 10HP gas engine 1.0-1.5 qts?? You can always drain it and measure. Than add it back...Good Luck
What does this Y148-8009A1 and 491300 mean on the back of a pulsar P watch
Y148 is the quartz movement model, 8009 is the case number.
The 491300 is the serial number, which means that the watch was produced in January of either 1994, 2004, or 2014. I have no idea what the A1 in a box is for. I hope this helps.
May 31, 2016 | Pulsar Watches
Watch serial numbers
Model numbers and battery details etc. on Pulsar watches are normally stamped on the back plate but the serial numbers can sometimes be found on the inside of the back plate.
Jan 06, 2014 | Pulsar Watches
What generation this iPod is serial number 1A009QC075J
iPods come in a variety of generations and models, including the nano, Classic and Touch. Depending on your model you may be able to record video, play games or watch television.
If you're unsure of your device's model, you can determine which iPod you have by using your serial number.
After determining your model, you can find out which features and capabilities your iPod has.
Go to Apple's official website (see Link Below) and click the Support tab.
http://www.apple.com/
Click the Online Service Assistant link, which is located in the Support Services menu on the right side of the screen.
The Service and Repair page will open.
Find your iPod's serial number.
This is engraved somewhere on the back of your iPod, either on the body of the device or on the clip.
You can also find it in your iPod's About screen by clicking Settings and selecting About (or General followed by About on an iPod Touch).
Enter your iPod's serial number and click the "Continue" button.
Your iPod model and generation will be displayed at the top of the screen.
http://support.apple.com/kb/HT1353
also
With each new generation of the iPod Touch, you get new features and updates to the older generation.
The 2nd and 3rd generation iPod Touches are very similar in physical appearance.
The easiest way to determine what generation of iPod Touch you have is to check the model number on the back of the device.
The 2nd and 3rd generation iPod Touches were given unique model numbers to help distinguish your device generation.
Remove any protective case from the iPod Touch so you can see the back of the device.
Locate the model number at the bottom of the back of the device.
Check the model number against the following model numbers.
Third generation iPod Touches are model number "A1318." Second generation iPod Touches are model number "A1288."
Identifying iPod models
http://support.apple.com/kb/ht1353
Aug 10, 2013 | Apple iPod touch
Looking for a serial number for Regzooka. I have the program no serial though
Serial Key Generator is specially designed to help you protect your applications by serial key registration. It allows you to quickly generate serial keys and prepare them for online or offline validation by your applications. You can generate and export serial keys into files (plain text or encrypted registration files) or to use MySQL Query generator to export serial keys onto MySQL database for online software registration.go tohttp://freedownloadmanager.org/downloads/serial-key-gen-for-regzooka-1757463.html
Apr 29, 2011 | Computers & Internet
Adobe photoshop cs3 serial number 1330-1751-1921-7520-1721-1350 activation 4373-2829-9684-6024-9758-5702-4895 please send me a authorization code ;) amrbasha_6@hotmail.com
1)use the keygen to generate a serial
2)use that serial to register
3)cs3 will then give you a few options you select activate by phone
4)a serial number will be provided by cs3
5)you paste this into the lower box of the keygen then select generate
6)the number generated will be what you use to activate the software
note all this will need to be done without closing down the setup process because the serial numbers will only work with the codes that generated them
hope this helps,it is really simple once you do it once
Mar 31, 2011 | Adobe Computers & Internet
19 people viewed this question
k24674
jasbo
jasbo
