Question about Emjoi AY-5 Epilator
I have an old philishave 545 triple header, i need new blades
The cutters are dull
TRIMMER IS STUCK. HOW COULD I FIX IT?
Push a thin knife blade between the trimmer cutter and comb blades, they are stuck together. Then lubricate it while running.
May 19, 2015 | Health & Beauty
My blades are a little dull will the blades still cut through a bolt?
You shouldn't really be using dull bolt cutters because it requires more force to cut through the metal which increases the likelyhood that you will get an injury. Yes you can use dull bolt cutters but you should always make sure that your blades are sharp before you use them.
Nov 14, 2013 | Cutter Tools
Blade head assembly for Philishave 925
Replacement heads for model HS925 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/philips-norelco/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Mar 21, 2013 | Health & Beauty
Trying to buy new blades for philishave HQ5812 but cant find any do you have any suggestions?
Usually they make this Philips so when the blade wears out you are force to buy a new equipment once again, I was looking for the blades by itself but can't find it
Thanks
Jun 03, 2011 | Philips Philishave HQ5812 Electric Shaver
In-sink-erator is blocked and does not empty. The blades go around, and there is not food waste in the actual unit, but nothing gets mulched up.
if you ran it dry at any time the cutters get dull w/o a supply of fresh water when running, now the food is getting by the dull cutters and have the "P" trap below the disposal plugged with oversized food particles, also if you grind up celery it gets stringy and can plug disposers
Oct 18, 2009 | Kitchen Appliances - Others
Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
My viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Nov 05, 2008 | Husqvarna Viking 1
Need shaving heads for hq177 philips shaver, where will i get replacement heads, live in se14 5ae
My store carries the heads for your Norelco shaver. I can ship them to you. Please call toll free 1-888-643-9806 and ask for Action Mike
Jun 06, 2008 | Philips Philishave HQ7780 Electric Shaver
Emjoi AY-5 Epilator Logo
93 people viewed this question
Top Emjoi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Emjoi Health and Beauty Expert? Answer questions, earn points and help others
