Question about LG Studioworks 700S 17" CRT Monitor
Want to connect game on laptop
I wanted to make vga female to tv video female cable
  • 65 Answers
Vga uses separate rgb (red, green, blue) connections to compose a video signal, sync and resolution, whereas the video female uses an analog signal with different signal info. you need to get a tv out adapter for your pc that cames with a the display hardware. look for video cards with video out or if you have a digital tv, with hdmi or dvi out. good luck
Posted on May 20, 2009
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Does my HP dv9449us has HDMI port? Can I connect it with my tv using this cable or what cables do I need? We have LG LCD tv.
Your laptop does not have a HDMI port. You only have VGA, you have to purchase a VGA to VGA cable VGA is video only interface. So you will need it along with the stereo audio cable
http://pctvcables.com/vga-with-audio-pc-to-tv-cables.html
Note that the stereo audio cable shoulb be connected from the headphones jack on your laptop to the headphones jack on you home theater system if you have one or buy this adapter plug the stereo audio cable coming from the laptop into it and connect it to the stereo audio in (red and white audio)of your tv
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
Aug 18, 2011 | HP Pavilion DV6449US Notebook
I have a inspiron1300,and i wondered if it is possibe to connect it to my philips hdready tv.am sure which cable to use
You never mentioned what model Philips TV you have, however I've researched several and most seem to have a VGA video port in the back of them. If you have one of these (15 pin D connector) on the back of your TV you should be able to purchase a corresponding VGA cable (you'll want female pins on one side of the cable and male pins on the other side) and plug one side into the VGA port on your laptop and the other cable into the TV. Then use your TV remote to select that input. Should work fine!
See item 8 in the attached user guide link to see what I'm talking about. http://download.p4c.philips.com/files/4/42pfl3403_98/42pfl3403_98_qsg_eng.pdf
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 23, 2011 | Computers & Internet
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
Connect a acer aspire to a tv to play films does it have a vga card??
Please check the ports at the bacj your tv if it has a vga-in. If it does, then you can connect a vga cord, then set your laptop to display on external viewing device by pressing Alt+F5 or please see the manual that came with your Acer Aspire.
Apr 01, 2010 | Computers & Internet
Can i connect my acer 10.1 to my tv ?
yes if it is LCD tv you can using the VGA cable
Dec 30, 2009 | Acer Aspire One PC Notebook
Cable from pc to tv
Have you gone into your display settings on your laptop and changed it to an extended desktop?
Oct 23, 2009 | Toshiba Satellite A135-S2386 Notebook
How can I connect the Asus K50IN laptop to a TV?
if your tv is a newer hdtv it might have a 15 pin female vga connector in the back. I just use a vga cable from my notebook to my tv. make sure the vga cable is female on both ends. works great!
Oct 10, 2009 | ASUS Computers & Internet
LG Studioworks 700S 17" CRT Monitor Logo
98 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
