Question about Estate Dryers
How to get to the belt to put a new one on
Put a dryern belt on a estats dryern tedx640jq
  • 460 Answers
To better assist you I need to know
what brand is your dryer n model n serial#
Thank you
Posted on May 21, 2009
The inner drum stopped turning
Possible broken belt, also if you have an idler with Teflon glide, replace idler with one that has a roller on it
Nov 30, 2013 | Estate TEDX640JQ Electric Dryer
My kitchen aid dryer kgys758lq8 does not turn when drying its a gas dryer
First thought is broken belt or bad motor
Could be a relay or contactor that is bad that controls the motor too.
Aug 23, 2013 | Estate TEDX640JQ Electric Dryer
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
Estate dryer tensioner loose while installing belt
Go to www.appliancehelponline.com/servicemanual.html there is a video that will show you how to replace it. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Apr 28, 2010 | Estate TEDX640JQ Electric Dryer
Drum does not turn,not very old ,cannot access inside
Sounds as if you have a broken belt.
If your machine is a front loading machine, then you would normally access the belt by removing the front of the machine.
This will expose the drum and belt, if you remove the drum, then it will expose the rollers, idler arm with pulley, and motor.
I hope this helps
Oct 02, 2009 | Estate TEDX640JQ Electric Dryer
The dryer cycle is not working. It stays still instead of going around.
Ok but is it making any kind of noise? If it is making a noise then you will need to possibly replace the belt. call your authorize technician to replace the belt and they can also check and clean you lint traps and the insed of the unit.
Cheers
Al
Sep 11, 2009 | Estate TEDX640JQ Electric Dryer
How do i replace belt on my estate whirlpool dryer?
Check out the video at the link I am providing. It should assist you in the belt replacement. Sure hope so anyway! Hope this helped and best wishes.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
How to put a belt on a estats dryern tedx640jq
open lint trap door and remove two screws. pull lid toward you and lift up at front edge. on either side of the front door panel there is a 5/16" sheet metal screw. when screws are removed, pull top of door panel out to clear drum and lift. should be able to access drum and idler from there but make sure you unplug dryer first, double check belt for twists, rotate drum back and forth. While your in there you should clean out lint and check rollers.
May 20, 2009 | Estate TEDX640JQ Electric Dryer
Dryers Logo
61 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
