Question about Eltax AVR-200 5.1 Channels Receiver
Eltax AVR-200 displaying error 1
Every time i turn on my eltax AVR-200, it says error 1 please help me with this problem
Eltax Atomic A-8 A8 Active Subwoofer i have a burnt out power transformer
Power transformers are safety parts and should only be replaced by the same type or one specified by Eltax the maker. You should contact them for the spare parts department or the place that stocks them.
Jun 01, 2013 | Audio Players & Recorders
How can i resetting my avr 587 to the factory default. I can't get it to work correct now. volume comes on wide open when i turn it on.
Assuming you mean a Denon AVR 587,
1. Turn the unit off.
2. Press and hold Speaker A and B buttons at the same time.
3. Still holding Speaker A and B buttons, press the Power button to turn the unit on.
4. The display should flash on and off at 1 second intervals.
5. Release the Speaker A and B buttons.
Jan 28, 2011 | Audio Players & Recorders
I have Arcam Receiver AVR 300. I bought it used a few months ago and the receiver had worked like a dream. Suddenly, for no apparent reason, there was no sound from the SAT channel/output where the...
Seems you set it to "Stereo Direct" mode. This is an analog only mode, while you are using a digital signal. You can change this with the mode button.
Press menu, on the main menu screen 1, scroll down to stereo direct. Turn this OFF.
This should solve your issue!
~KenjiFox
Jan 07, 2011 | Arcam AVR-200 Receiver
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
Denon avr 2308 no subwoofer operation
is the sub in speaker set A and sub in set B?
that was my problem on Denon DRA-455 with Eltax Linear 6.5
May 29, 2009 | Denon AVR-2308CI
Loud boom when going in standby mode.
i would check your sub connection also make sure the volume isnt set to high. sometimes unplugging the power and cables also helps
May 20, 2009 | Eltax Atomic A-8.2 Subwoofer
720p output doesn't work
The problem might be that the set can not handle the change in signal. Try setting the AVR-247 to 720P first then turning on the set. Or manually set the TV to receive 720P then change the AVR. TI believe that you have a connectivity issue where the two units are not speaking the same language at the same time. Update this with your results and please post the TV make and model.
Thanks,
Dan
Apr 01, 2008 | Harman Kardon AVR 240 Receiver
Eltax avr-200 no sound
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
Jan 12, 2008 | Audio Players & Recorders
Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Eltax AVR-200 5.1 Channels Receiver Logo
52 people viewed this question
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
