Proform Perspective Es Treadmill PFTL99806 Logo
A
Anonymous Posted on Apr 16, 2017
Alittle more details on the problems Iam have with the proform perspective Es treadmill PFTL99806. I have done everything the trouble shooting manaul has told me to d.. The machine is stuck in the highest incline position. The trouble shooting manual tells me to press an incline button and remove the safety key, wait a few second and replace the key. The machine should incline all the way up and then back down to recalibrate. What happens is it raises about an inch from the top and then lowers about the same and stops. It will not lower all the way down. I hope this makes sense
1 Related Answer
Anonymous
  • 999 Answers
  • Posted on Jun 17, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Proform perspective 1.0 lx console cycling off and on
There may be a problem with the wire lume that connects the LCB to the console.
Repco rp300tm
1) reset the treadmil.2) adjust the speed sensor, see the diagram attached. 3) Run the software calibration for easy diagnostic and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button 31d332da-cd1c-4885-8ae4-393941ca1930.gif
Proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
1helpful
Belt is sliding to right and is loose how do I tighten it? Proform Perspective ES
see the diagram attached and use the common sense:
God bless you
8_30_2012_4_32_35_pm.gifthe first if for to tight8_30_2012_4_33_22_pm.gifthe down is for loose.
5helpful
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
