Question about Farenheit WLHP-100 Wireless Infrared Headphone
Manual farenheit no transmitter enclosed in box, how does one pair the headphones to the "TV", computer, etc.
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
How to connect wireless headphones to TV
The TV has to have bluetooth connection or a place to insert a bluetooth dongle, so the headphones can be paired with the tv
Feb 16, 2015 | Ematic Wireless Headphones and Transmitter
Just bought a Samsung smart tv and a pair of brookstone wireless tv headphones, however after setting the transmitter I am unable to get any sound on the headphones. I do not have a cable box or gaming...
try your headphones on another device to ensure the headphones are not the problem. ensure any mute or volume switch on the headphones are turned up. and ensure the batteries in the headphone are charged. check attn try both 0 and -8db setting,
check both headphone outlet and tv speaker outlet of smart tv. in TV settings ensure the audio out setting is set to ON so that the jacks for audio to external speaker are switched on.
i hope this was useful.
Dec 26, 2014 | Audio Players & Recorders
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
Bluetooth adapter for TV
User Fm transmitter instead of Bluetooth transmitter......i doubt bluetooth adapter will work on tv with headphones..
Dec 26, 2013 | Eforcity Computers & Internet
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
Aug 14, 2011 | Audio Players & Recorders
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
No charge for xbox wireless headphones
There should be lights on the front of the headset's transmitter box. Are these lit up?
Also, there should be a "palm tree" icon on the left earcup of the headset. When you turn on the headset from the POWER button, the palm tree should flash about once a second. Is it flashing?
If not, you may need to "pair" the headset to the transmitter.
Mar 17, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Farenheit WLHP-100 Wireless Infrared Headphone Logo
29 people viewed this question
Top Farenheit Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Farenheit Audio Player and Recorder Expert? Answer questions, earn points and help others
