I have model LSC9355BWO. I want to know the capacity of this older model. Can you help?
Lost manuel, need to know how much oil i need when changing the oil& filter!
You didn't provide any make and model details so can't provide any specifics.
Knowing the oil capacity is helpful when buying oil but when it comes to refilling the engine the stated capacity is only a guide and is not a substitute for filling to the correct level using the dipstick or level plug and a deal of patience, especially in an older engine where a build-up of sludge can cause an engine to be over-full with the correct quantity of oil.
Buying just the one or two litres of oil a small engine might need is a rather expensive way of buying oil and leaves little left over for topping up.
Far better to buy a 5litre can or a gallon and have the benefit of saving money long-term and having plenty of oil on the shelf for topping up and using in the oilcan and maybe enough left over for the next oil change at the end of the season.
May 21, 2016 | Garden
I have two TVs, a Toshiba in my living room and a Sylvania in the bedroom, both of which are connected to Time Warner cable. They are both older version televisions, not flat screens or plasma. The Sy
You haven't specified here about the channel capacity or both of your Televisions. Is both of it can receive 100 channels. If not, the tuner to both will have the difference. There are sets with which can receive only 50 channels, 90 channels, 120 channels etc: Older versions of TVs will have only low channel capacity. Present ones are of channel receiving capacity up-to 320.
If the channel receiving capacity to your TV is low [as it is older models]; there is nothing more to do. Electro help
Nov 16, 2014 | Toshiba Televison & Video
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
Feb 22, 2014 | Washing Machines
Need to know capacity of my Kenmore Elite model 110.76992501 gas dryer (purchased about 6 years ago) from Sears in California
Hello, about 3 kids if they are younger. Now, if they are older maybe two with extra arm.
About 10 to 13 lbs of wet clothes or one kid if he/she is dripping wet. Have a very nice day. GB...stewbison
Sep 22, 2011 | Dryers
MAMARY CARD PHOTO NOT REEDING
It may be that you have an older version of a camera that does not support a large capacity memory card. Before you panic, try to format the card in the camera. It would help to know excatly which model of camera you have.
Oct 06, 2010 | Cameras
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
Looking for capacity on my older Maytag washer
the capacity of your machine is six cubic feet. That is a box 2 feet by 2 feet by 18 inches.
Apr 11, 2009 | Washing Machines
I need to know ram memory capacity and type of memory
Easiest thing to do is go to www.crucial.com and run their Scan Program. It works well. It will tell you what kind of RAM you need, how much you now have and the max you can install.
Mar 09, 2009 | Computers & Internet
Electronic flash capacitors
Maybe I can help.
Is it the main capacity?
atdlee@netzero.com
Dec 10, 2007 | Cameras
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
