Question about Coffee Makers & Espresso Machines
Bunn stf 15 - Coffee Makers & Espresso Machines
5 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Set flow amount on Bunn STF 35
Remove the top panel and look for the yellow float, this controls the amount of water brewed, to adjust remove some of the washers on the float and test until you get the amount needed.
Posted on Jul 24, 2009
  • 3289 Answers
SOURCE: I BOUGHT A USED BUNN COFFEE MACHINE STF-15. IT
This is usually the result of an incorrectly set timer (see p. 22 & p. 24 of manual) or stuck solenoid valve (p. 18). A link to the owner's manual is provided below. You should read the manual thoroughly before attempting adjustments & repairs.
http://www.bunn.com/pdfs/commercial/manuals/29251.0000.pdf
I hope this helps!
Posted on Oct 20, 2009
  • 124 Answers
SOURCE: Bunn-O-Matic Model STF 20 is making loud noises
You may have a thermostat problem.
Contact a Bunn service center and have the unit checked.
Posted on Jan 03, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a Bunn Model STF-15. Water fills then
If the solenoid is working properly then the float switch for the brew volume needs to be cleaned because it might have some build that weighing it down.
Posted on Nov 26, 2010
Cannot view STF file format
there are many free online converters on the web. Convert the file from STF to JPEG, GIFF etc.
Jan 27, 2014 | Polaroid Photo Media Backup Device...
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
What is the best way to clean a Bunn STF-20 coffee maker. It has a water line connection,
Clean with white vinegar, run it through 3 times, then you are set.
Oct 09, 2012 | Refrigerators
CWT 15-APS Coffee Maker: How do I get into the back of a CW series brewer t...
You have to get to it from the front panel. Remove the 6 screws for access.
May 18, 2010 | Bunn CWT 15-APS Coffee Maker
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Bunn-O-Matic Model STF 20 is making loud noises and spewing water after brewing is complete
Nov 07, 2009 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
I BOUGHT A USED BUNN COFFEE MACHINE STF-15. IT CAME WITH THREE POTS THAT HAVE THE NAME ELLIS COFFEE ON THEM. PART #2097 0202. WHEN I RUNS IT THE POT OVER FILLS. DO I HAVE THE WRONG POT OR IS THERE AN...
I hope this helps!
Oct 20, 2009 | Coffee Makers & Espresso Machines
Jul 24, 2009 | Coffee Makers & Espresso Machines
I have a STF-35 , brews more then the pot , can you adjust the amount of water per brew ?
Yes, but you need the pre weighed grommets from bunn, if you remove the top panel on the machine you will see the brew tank, within that there will be brown plastic shaft with a yellowish cylinder on top of it. There might be 3 or 4 washers on top of that yellow piece, those are the weights, when the water fills the tank it pushes the float up and when it reaches the top it turns off the solenoid. You should be able to try it without the top on.
Jun 24, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
