Question about Citizen iDP-3550 Matrix Printer
Idp3550 dosnt print - Citizen iDP-3550 Matrix Printer
Why does it say add paper in cassette 1 but cassette is full
sorry man we had the same problem theres a black tab on the back of the tray that pushes the paper back so it dosnt go over the back remove it or buy the mod kit for it we simple removed it
Jul 29, 2014 | Kyocera Ecosys FS-2100DN Laser Printer -...
Dosnt print
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 26, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Epson Acculaser c1100 ink blead
First rule out that it is a paper issue by trying a different type of paper
If that dosnt work
check if the gradation setting is too small when printing graphics. On the Basic Setting menu in the printer driver, click More Settings, adjust the gradation setting by sliding the Contrast slider bar
If that dosnt work
Clean the print head .
see steps at the bottom
If that dosnt work
It is starting to look like drum/photoconductor problem, this may need to be replaced (the most expensive solution)
Follow the steps below to clean the printer head.
r_1.gif Open the cleaner cover on the right side of the printer. Then, open cover A. d580095.gif
r_space.gif r_note.gif Note: r_space.gif r_space.gif Move the cleaner completely in and out. Otherwise, the printer may not be cleaned effectively. r_4.gif Push back the blue lever on the right inside of the printer. d580098.gif
Sep 11, 2009 | Epson Aculaser C1100 Printer
New print head, won't print
If it's a Canon machine, you will need a purge unit. If it doesn't clean and prime properly, it
will just give you blank paper.
Jul 27, 2009 | Office Equipment & Supplies
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Apr 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
Why dosnt my hp C4380 print disc labels in roxio creator 9
Hi ChasAtPark -
Can you please clarify how you are unable to print disc labels? Can you print in other applications? Do you have your latest drivers for your printer? Are these paper labels or lightscribe?
Also, you can submit a free web-ticket here (must be registered) if you prefer one on one support.
Thanks,
Jon
Roxio Support
Apr 20, 2008 | Computers & Internet
Citizen iDP-3550 Matrix Printer Logo
140 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
