Question about Ovens
Edinoliva gas stove manual - Ovens
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
Whirlpool owners manual gas stove W10198615D
Most Whirlpool model numbers start with two or three letters and have another two letters later in the number. W10198615D may be your serial number or a Lowe's product number, not the Whirlpool model number.
Usually though the model number and serial number aren't on the back of the stove. The plaque with this data is on the rim of the oven behind the warming or storage drawer.
The manuals that are available are here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
Please recheck your model number and post a comment with the correct model number. I'll be glad to try to get the correct manual for you.
I wish that I could be of more help right now.
Dec 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
Nov 27, 2009 | Stoves Premier 900GRa Gas Double Oven
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Mar 06, 2009 | Stoves Ovens
Ovens Logo
81 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
