Question about Samsung WF209ANW 40 cu. ft. Front Load Washer
Samsung WA5471AB 4.cu. ft. Top Load Washer bleach dispenser has dry bleach residue
There's dry bleach residue in the bleach dispenser. Several of my clothes have bleach spots where the bleach took out the color. I'm assuming the bleach dispenser isn't working correctly.
SOURCE: Samsung WF337AR front load washer
use weaker bleach
Posted on Jan 04, 2008
  • 15 Answers
SOURCE: I would like to know how many items you can put
theary is 4 pairs of jeans 4bath towels without any small items
Posted on May 03, 2009
SOURCE: prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
Posted on May 23, 2009
wrehab
  • 91 Answers
SOURCE: Bleach is eating holes in
Add your bleach with less potency but make sure you are putting it where it is suppose to go and when you are supose to add it , it makes a difference.
Posted on Jan 02, 2011
SOURCE: When I used chlorine bleach, it made large bleach
I would only put soap,bleach etc in the water first
Then add clothes after it is mixed
The newer front load machines are a problem
Posted on Jan 30, 2011
PE error (Clutch Motor Error) how is this repaired?
NOT SURE ABOUT UR MODEL BUT THE CLUTCH ASSEMBLY IS PRETTY BASIC AND COMMON, U MAY NEED TO REPLACE IT, ARE U HAVING SPIN PROBLEMS ( SLOW SPIN OR NO SPIN) OR LEFT WITH WET CLOTHES NOT SPINNING DRY.
May 18, 2015 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Why is the water not filling in my washing machine
There are screen filters at the inlets on the machine where water hoses connect. When they get clogged the water flow is slowed.
Dec 13, 2014 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
I have deep rust appearing around the bleach port. machine is only one year old. WHY is it rusting ?????
Samsung does not recommend the use of chlorine bleach in this machine. The bleach port is intended for color-safe bleach only. Chlorine bleach is an oxidizer that will accelerate the corrosion process of the drum, which is what you are probably seeing. The users guide for your machine states specifically that you SHOULD NOT put liquid chlorine bleach into the bleach port.
Aug 13, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
Why does it not drain?
It "should drain automatically. If yours does not, please make sure the washer is properly leveled both front to back and side to side, make sure the drain hose is not inserted too far into the drain pipe and that there are no bends or kinks in the drain hose that might cause a blockage. Samsung also recommends cleaning the debris filter on a regular basis (at least once per month). To avoid spillage when cleaning the debris filter, it's important to first empty the rubber drain tube located next to the debris filter into a container. For more information, please refer to the User Manual."
Source: http://answers.us.samsung.com/answers/7463/product/WF330ANB_XAA/samsung-4-3-cu-ft-washer-questions-answers/questions.htm
You can download the "User Manual" and "Troubleshooting Guide" from here:
http://www.samsung.com/us/support/owners/product/WA5471ABW/XAA
I hope that helps you!
Jun 21, 2014 | Samsung WA5471AB 4.7 Cu. Ft. Top Load...
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Samsung WF209ANW 40 cu. ft. Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
