Question about Daewoo KOR-630A Microwave Oven
I want manual how to use this microwave
I want to know how toprepare food in this microwave
    Master:
    Sergeant:
  • 461 Answers
YOu can get the manual from below link
http://etech.maiila.com/daewood-microwave-oven-kor-630a
Posted on May 20, 2009
I have the Dacor DCM24 microwave and if the table does not spin will the microwave still cook food. I think my turn motor is bad, but wanted to know if I could cook food without it?
Yes! it will continue to cook food, the only difference you may end up with cold spots in the food, rotate plate once or twice to reduce this.
May 30, 2012 | Dacor DCM24 Convection/Microwave Oven
Everything on the microwave works (e.g., turntable lights, controls, etc.) except it will not heat food, defrost food etc. It sounds like a magnatron. Any Ideas before I call a tech? Is there a online...
It does sound like the magnetron, but you need to check the high voltage capacitor and diode because they can be the problem. I don't know if there is a online manual.
Apr 10, 2011 | Microwave Ovens
MY LG microwave oven model no MH6344W does not heat the food .The oven is fine after 1 minute microwaving if i remove the food it is as cold as it was. What would be the reason please explain. I tried...
If the food is not being heated it means the magnetron is not working. The magnetron is the device which generates microwaves which heat the food. It could be the magnetron itself which is faulty or it could be one or 2 other components causing the magnetron not to work. You will have to take your microwave oven to a service center to determine the exact cause & get a repair quotation.
Let me know if you need further assistance.
Best wishes,
Graeme
Mar 17, 2011 | Microwave Ovens
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
Error message SE
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect .
I hope this will help you .
please rate !
Mar 29, 2010 | Frigidaire Microwave Ovens
Looking for a manual so i can defrost food
Hi!
Try manualzone.com, you will need the brand and model number! I hope this is helpful, good luck!
Mar 12, 2009 | Siemens Microwave Ovens
Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Feb 05, 2009 | Cuisinart CWM-100 Microwave Oven
I dont know how to use my microwave oven for cooking food.
i dont know how to set temperature and cook in microwave ovan
Jan 31, 2009 | LG LMH1017 Convection Microwave Oven
Food
read the manual..............
Sep 24, 2008 | Microwave Ovens
User manual BRE799GMSSE
i have a microwave Breville.Ia working but is not heating the food.What is the problem?What should i do?
Feb 25, 2008 | Microwave Ovens
Daewoo KOR-630A Microwave Oven Logo
247 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
