Question about Canon PowerShot A560 Digital Camera
Cannot download the solution disk
I am not able to download the digital camera solution disk.there comes an error of low resolution..
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Posted on Oct 08, 2012
Nightdiver
  • 116 Answers
SOURCE: disk error
Hello anuhera, This is a very common problem with the cd400 camera, I have learned the hard way that Sony's recommendation to use their [expensive] media was more than just self interest. There are a lot of quality issues with CD media. As my camera has aged it is more and more intolerant of off-brand media. This is true even though I have not shot more than a 1000 images with the camera. While I can plan on getting the c:13:01 error with unbranded disks, I can still use the Sony disks without much if any problem. To get your pictures back, go to www.cdroller.com and download their recovery software, worked great for me. Let me know if you need any additional info. Best regards, nightdiver
Posted on May 30, 2006
MrsJGreen
  • 130 Answers
SOURCE: Screen resolution to execute digital camera solution disk is not sufficient
Go to start/control panel/display/settings/adjust your screen resolution to high and then install.
Once installed, change your screen resolution back as low or high as you wish.
Posted on May 30, 2008
old marine
  • 1986 Answers
SOURCE: Inserted the disk for my
You have to set the resolution on your computer's monitor to the minimum required to run the software. To do this, go to your desktop (no programs showing) and right click in an empty area on the desktop. Go down to "Properties" on the menu that appears and click on it. Look along the top of the window that opens for a tab named "Settings" and click on it. You should see an option (usually on the left) to change your screen resolution. Change your resolution to the minimum required for the program. Depending on your computer, you may be asked to confirm the new settings, or you may have to restart your computer (the computer will tell you). Once you have the new screen resolution set, things will appear to be smaller on the monitor, but you will be able to see more of whatever you are looking at.
Posted on Oct 06, 2008
SOURCE: installation for the downloading in the computer
hello! you speak portuguese!!
Posted on Nov 22, 2008
SOURCE: I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Posted on Jun 28, 2009
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
Error in D70s
The r07 is just a display that tells you how many pictures you have memory for in the buffer. It's not an error code at all. It will change when you change resolution, since pictures at low resolution take less memory than at high resolution. On the D70s this number will go from about r04 to r11 as you go from RAW down to low resolution.
Jan 28, 2010 | Nikon D70s Digital Camera
Canon Rebel EOS - Pictures download read Low Resolution
Canon Digital Rebel cameras let you set the image resolution from small jpegs (low resolution) to large jpegs (high resolution) to RAW (best quality, but require post-processing in your computer before you can print them). It's possible that as you were getting to know your camera you accidentally set the image size and quality to a low setting. Now you just need to change it back!
You make this change in the on-screen menu, under the camera menu (first menu, with a camera icon), first item (Quality). Although Canon no longer has the manual for this camera online, you can see This Review Page for more details on where to change this setting on your camera.
Dec 18, 2008 | Canon Digital Rebel / EOS-300D Digital...
Hi, I just bought a Canon Rebel, and I'm trying to download the EOS Digital Solution DIsck and I'm getting a message that says my screen resoltution is not sufficient? Help.
This is an easy fix.
Go to your control panel. Click start/control panel/display/settings.
There you will find your screen resolution slider. Slide all the way up to high resolution and apply settings. Your icons and everything on your screen will be smaller.
Install disk and go back and set your resolution as low or high as you wish once installed!
Hope this helps!
May 29, 2008 | Canon Cameras
Apr 20, 2008 | Canon PowerShot S5 IS Digital Camera
Download disk
Hi , this is my problem for my camera before : Open control panel click scanner and camera icon /on the power of the camera insert the usb , sound beep alert camera icon will appear ,add camera device then follow instruction on screen .
check also device manager .goodluck
Jan 10, 2008 | Canon PowerShot A560 Digital Camera
Poor printing resolution...?!
You can select whatever resolution you want to print at on your Print(er) Setup.
If your Printer is automatically selecting a 72DPI to print at, you may be trying to print a 10X12 pic size or larger by default due to pic file size created when pic was taken in camera with full 7Meg resolution.
Use photo software to proper size the print before printing. If you want a print larger than 5X7, keep in mind the TZ3 begins to have recognizable noise, reduced resolution due to noise, especially in low light indoor or evening/nite outside shots. You can use photo software to improve and size them before printing. Windows Vista has a built-in photoshop type program. Else, I believe your camera comes with one on disk.
Also, read your manual regarding shooting with this camera.
Nov 09, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Can't install the solution disk
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Sep 13, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A560 Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
