Question about Sony Bravia KDL-46VL130 TV
Model kdl-405300, pixel streaks and distorts half the screen, more so when watching live sports.
3 Suggested Answers
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Posted on Oct 18, 2008
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Sony tv troubleshooting
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. It has troubleshooting tips.
Dec 31, 2013 | Televison & Video
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Kdl 40ex520
This problem could be from a circuit resistor, it needs to be replace. Believe it or not this a common problem on most TV that are build to save money to the manufacturer.
May 16, 2017 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
I have had a dark distortion on half the screen for some time now but it would snap back to a regular picture after half an hour or so . But now the dar and distortion won't go away. Any help out...
Their is most likely a problem with the pixels in your display. the reason why it dose this is that after the television warms up (about half and hour) the pixels adjust and start to work properly the only fix would be to replace the entire screen
Mar 05, 2011 | Sanyo DP46849 46 in. HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Distortion and horizontl lines
    If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
    Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
    Thanks.
    Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
    Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
    Sony Bravia KDL-46VL130 TV Logo
    43 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
