Color issue I was downloading a program yesterday and i saw something about the color and I hit the button on my laptop and now the color screen is messed up and i don't know what to do. can you help
    Scholar:
  • 81 Answers
Go to control panel, if using xp go to sytem, then devise manager, go to your dispaly adapter and right mouse it, then hit update driver (automatically) and see if it fixs the problem.
Posted on May 20, 2009
Laptop negative screen
- Go to start button and Then type "magnifier" in the search bar (where it says "search programs and files") then when you see it open it and click on the cog button (settings) and then uncheck the box which says color inversion.
Also try to to update your graphic drivers in safe mode
If this helpless then simply get the Reginout to Fix all registry issues which creating this annoying issue
Jun 20, 2013 | HP EliteBook Computers & Internet
My laptop symptoms are faded lines, fonts not crisp, various shades of the same color in the lines. I have replaced the monitor but that did not ellimnate the problem. I have a Dell Inspiron...
  1. Turn off the Computer.
  2. Hold Down the FN Key on the keyboard and press the power button, then Release both buttons.
  3. This should start your PSA Diagnostics
  4. You will see two color bar screens appear in succession, on the second color bar screen there is a message asking you if you saw the color bars. Press the N key for No to start the LCD BIST.
  5. The LCD BIST will run several full colored screens in succession with a beeping sound.
  6. Check for any lines, distortions, or abnormalities you were seeing in the Operating System here.
  7. Once the Diagnostics are finished you will see an Error message appear, this is Normal. Press the N Key to end the Diagnostics or Press the Y Key to continue the PSA Diagnostics.
  8. If no sysmptoms were displayed please continue on to the next step, if they were displayed please go to the last step.
An out of date Video Driver or BIOS can cause abnormal screen issues.
Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
If you need assistance in Downloading and Installing Drivers or BIOS. Click here for Installation Instructions
Click Here to Launch the Dell Drivers and Downloads Website
Dec 03, 2010 | Dell Inspiron 6000 Notebook
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
Dell Inspiron E1705: Getting lines/blocks of color on monitor
From a power off state, press the Fn key and the power button, this will run the BIST which is a diagnostic on the LCD, if you get screens of solid colors.
From what you describe, I'd suspect the video card which could be the motherboard or memory, try the memory modules one at a time, see if the issue only occurs with one module
Feb 28, 2010 | Dell Inspiron E1705 Notebook
My compaq presario v2000 has a fuzzy screen and the colors on the backgrounds that are supposed to be white are like and aqua green color and i was just wondering how to fix it. Is there something i can...
First thing you want to try is getting the laptop to display on an external monitor. If it doesn't replicate the same issues then you know it is either the screen or the inverter/backlight.
if it does then it is most likely a motherboard issue and sadly can not be fixed outside of replacing the board.
Dec 10, 2009 | HP Compaq Presario V2000 Notebook
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
Toshiba portege s100-s1133 lcd screen
A pink or red screen which may gradually turn back to it's appropriate color indicates the lcd is going out. It could last quite some time in tht condition, but it's going. replacement isn't too bad though.
good luck
Jan 20, 2008 | Computers & Internet
Backlight
You my friend have a blown backlight! These things are repairable, but costly. Companies will tell you that, they will talk you into another PC! My suggestions is search online for a vendor that sells backlights for LCDs. This will resolve the issue!
Nov 26, 2007 | Sharp Actius GP22W Notebook
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Computers & Internet Logo
David Payne
David Payne
