Question about Stealth Cam Stc-u838ng Unit X Ops No Glo Scouting Camera
Has great day picutues, but terrible night pictures
It doesn't take all the pictures at night, i get some, maybe 1 or 2 then it skips and might take 1 more. takes great daytime photos. is there anything that can be done to fix it?
Hi mmcgee6,
You need to check the settings in the camera , as to whether it's selected on night mode or not , when you use the camera at night , and particularly if the light is not as bright as day light.
There should not be any problem with the night shoots from the camera if there is no problem in the day , it's just the settings that needs to be changed to night mode.
Also a good idea would be to set the flash settings on Auto instead of Off , or other settings , this will adjust the camera as per the environment in which you are clicking your pictures.
Hope this helps ....:)
Sep 01, 2011 | Moultrie D55 Digital Camera
I bought a tasco Digital Trail Camera it works great except that it does not take any night pictures did I forget a setting or is there a default?
If it takes no pictures then you set it for day only. If it takes pictures that are black then the capacitor that controls the flash is not functional.
Nov 08, 2010 | Sport & Outdoor - Others
CAR RUNS AND IDLES ROUGH, SOME BACKFIRING TYPE NOISES. WAS TOLD I HAD A IDLING MOTOR ISSUE. ALSO TRIED FUEL INJECTION CLEANER. THIS AM, CAR WAS OUTSIDE ALL NIGHT (UTAH), AND BATTERY HAD DRAINED (NO LIGHTS...
Sounds like a charging problem. When your battery runs low there is not enough current to operate the sensors properly. When you charged the battery it thought the system was fine till it gets low again. I would have your alternator checked and battery. Good luck and have a great day.
Jan 31, 2010 | 1994 Subaru Legacy Outdoor
Low light wont turn off!!!
number1 be sure that you,re using energizer lithium batteries only.they,re the best.2 because these cameras have such a small flash and its placed in the front of the camera instead of the top,they,re not really made for night shots.but from 3-5ft you should get great pics at very low light.just put it on auto,and ignore the low light message,press down and hold for 2seconds then release.you should get great pictures this way.good luck,hope i helped
Apr 29, 2009 | Samsung S860 Digital Camera
Night problems
have you tried it with the led flash mode
Sep 23, 2008 | Bushnell 11-9900 Camcorder
Grainy LCD display
Are you in night mode? Sounds like you are in a high gain setting, like ISO 3200 or night mode.
Jul 17, 2008 | Canon PowerShot SD1000 Digital Camera
Blue pictures
Hi maria,
first how did you take a picutre during daytime ? try the auto setting on the camera , perhaps you have it now in the night mode and that may cause your problem
Apr 12, 2008 | Kodak EasyShare C613 Digital Camera
Over exposure
Alrighty then on the camera switch the swith on top to the scene[scn] switch it should start off with high iso use the side button until you get to the part where it says ''night portrait'' then click ok and you should be fine.
Apr 09, 2008 | Kodak EasyShare C613 Digital Camera
Taking pictures with handycam
I have heard that that they are great for recording video but if you want great pic's you should use your digital camera. before buying mine they told me that it wouldn't take great still pic's because of the megapixels or something.
Dec 21, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Stealth Cam Stc-u838ng Unit X Ops No Glo Scouting Camera Logo
Top Stealth Cam Video Cameras Experts
Are you a Stealth Cam Video Camera Expert? Answer questions, earn points and help others
