Question about Dell UltraSharp 1907FP 19" LCD Monitor
Power Button Broken?
I have a Dell 1907FP Flat Panel Monitor. The Power button does not click and seems wobbly. It does not turn on power. It seems to be mechanically broken. Help
    Scholar:
  • 81 Answers
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
Posted on May 20, 2009
Won't turn on
is it connected to the power ? am pritty sure it is it could be the power cord or the power button broken ? worse case the screen.
Nov 09, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Button on monitor (1907FP flat panel) will not turn on when pushed,
you have to bring this monitor to the store and fix it or you have to remove the button itself and push it with a pen or a pin.
Aug 28, 2010 | Dell Dimension 2400 PC Desktop
The power button to the my DELL LCD monitor is stuck. It won't "click" when you push it like the 4 other buttons on the bottom of the monitor. I think it may be stuck in...Is there an easy way to fix...
This is very common problem with this series, the plastic actuator is broken off, very cheaply made and poorly design part.
I have lo luck locating this 5-button plastic switch assembly yet.
Be real carefule when separating the front bezel from the bac cover, it has very small ribbon cable attached to the front panel switch assembly that can easily be ripped apart.
http://s807.photobucket.com/home/budm/allalbums
Aug 18, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
DELL 1907FP MONITOR
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
Sep 06, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1704FPT just went dead, will not turn on not even yellow light on power button - just seems to have died. Is there a way to reset? or is it time for a new one?
First you need to troubleshoot a little. You should first try another power cable for the monitor, if that doesn't help, you might be able to open up the monitor case and check wether the button is broken. If the button is broken, you're going to have to improvise a new one, since new buttons aren't really being sold. If that isn't the case, or if you can't open up the monitor, take it to computer shop, these things are easier to fix if you can look at it. I hope this helps, Yannick.
Jun 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
I have a Dell monitor model 1704FPT,, seems like the power button has come loose inside.. Can I get inside to repair it .. Thank you
You can turn counter-clockwise the screwz at the back cover of your monitor to open it & check if the power button is loose or defective, even notice if some internal part/s are cold soldered / defective. However, if it's still under Warranty, I recommend to bring the unit to an authorized service center for a Free service check-up & replacement part/s. best regards
May 22, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
434 people viewed this question
Alun Cox
