The picture on TV is red
My Tv clour screen is red. some time, for a few time get appropriate colour.what do you suggest me?
  • 355 Answers
If your able to take the back off and have experience in soldering then you can look on the CRT board on the picture tube for cold solder joints, it should be quite visible. There are 3 transistors that look identical so I would look those over closely. Those are your Red, Green and Blue Video outputs. If you choose not to and want to take it in to a service center try and find one with Free Est. Notice on your screen if you have diagonal lines, if you don't, that's a good sign. Let me know what you decide!
Posted on May 20, 2009
I replaced lamp on my toshiba 50hm66 tv and now i got a black and white picture
Hello
As it is a DLP projection TV, there will be a colour wheel to filter colur. If the whell does not spins at all, or spins out of synchronisation, there will be no colour to the picture. Just check the clour wheel. If needy, replace it. Clean it with cleaning solution. If you don't have eneough knoledge in alaigning the colour wheel, just get help fro an expecienced service technician. There is an RPM [Rotation Per Minute] counter to count the number of rotation of the colour wheel. If this sensor has some fault with, the colour wheel won't syncronise to its original speed what it should be, resulting out of colour picture. OK.
Sep 14, 2011 | Toshiba 50HM66 52" Television
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Sep 13, 2011 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
My probleb is I have purchased be fore 13 years & noe the clour is changed and becomonig red what shall i do/ Brand Sony Model -B21L1 The problem is changed its colour in to Red I didinot...
hi,
check the base board plugged into the picture tubes neck. there may be some dry soldering. also check the video output transistor for red cathode in the same board. found faulty replace it. also check the voltage at the collector of red out put transistor it should be above 70 volt. if it is zero then picture tubes cathode is short. if so u should replace the picture tube. for any further help yo can contact through fixya.
ok
Dec 21, 2010 | Sony KV-20VM42 20 in. TV/VCR Combo
Pink color appearence when swith on tv for 1 minutes & wringles form on the screen
Hello
Pink colour denotes the absence of green colour dispay in your picture tube. I hereby gies an approximate voltages at the three cathodes of your picture tube socket solderings, and you just measure the voltages with reference to this. The voltages are approximate, and can chage up to 2% up or down.
Green Cathode = Pin number 9 [161VDC approx]; Blue Cathode = Pin number 8 [162VDC apprpx]; and Red cathode = Pin number 10 [157VDC approx]
If any of these voltage differes, the clolur related to that cahode will also rise or low, thath is if the cathode voltage goes very low, that clour will be prdominent, and if it goes high, that colour will not be there.
In your TVs case, the green cathode voltage now will be high. t may be due to a soldering loose to either to the picture tube base socket or at the terminals of the related transistor or Ic. It is best to resolder the suspected loose soldering points by applying a little more solder, as we in service field also do. It is very difficult to locate the exact loose soldering point and so I advice you to do so. If needs, replace the colour output transistors, of other devices if used. Just look at the voateg at pin number 9 at the picture tube base card. Resolder all the picture tube base socket pins. If you wants any more calrification, contact me through Fixya. Ok.
Nov 25, 2010 | Sony KV-T29CF1 TV
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Toshiba 2577db tv
sounds like the color control module has **** the bed
Apr 09, 2008 | Toshiba 35A44 35" TV
Phillips tv 32pw9544
it is 100% sure that your tube is ok.
there are few problems in different section like
  • sound section for no sound
  • video & crt base  due to low light in picture.
  • red video output circuit.
  • though problems are very easy & can be fixed at your house.but you need skilled technician.
Oct 16, 2007 | Televison & Video
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
