Question about Samsung T809 Cellular Phone
Stupid problem... Can you turn off the camera's sound? When it takes a picture it does this annoying fake shutter sound... Can you turn it off? I've tried going into the set-up but it doesn't give me an option, I know it's silly but it also drives me nuts!
  • Anonymous Feb 27, 2009
    there is no shutter off just 3 different shutter noises to choose from (memoir)
    Sergeant:
  • 452 Answers
When u switch on the camera, after than click on option on the left handsite of mobile than u click on camera settings over there u got the option of shutter sound click it off
Posted on Oct 19, 2007
Camera won't take pictures.
Go into the settings and select Clean CCD. It should be under the blue menu. The shutter curtain has a tendency to stick on this model. There was a recall on them way back when they first came out. 1a53cc1b-6da0-4b38-942c-78caadf51633.gif 1bcf9dee-9615-448f-a170-16ef0e446320.gif
Aug 18, 2014 | Konica Minolta Maxxum 7D / Dynax 7D...
My camera is a Pentax Optio m50, and there is no image on display. It's all dark and when I take a picture, it is also dark. Help me please. I've tried all settings.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 24, 2011 | Cameras
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
Jun 06, 2011 | Canon Cameras
My Canon PowerShot SD 1000 has this problem: when i turn on the camera, the display is black and i can`t see any image through.Same problem on the video mode. it doesn`t appear any error mesage. i tried to...
A stuck shutter is another common failure mode for digital cameras (including my wife's SD1000, which I have to fix every once in a while with the following easy technique).. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, for your camera model, I've found it best to just alternate back and forth between opening the battery door while taking a picture, and gently flicking the lens barrel with the tip of my finger. Usually, it only requires a few tries for my wife's camera, then it's good for another couple months.
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
How do you stop the beeping sound when you press the menu biuttons etc e.g. like to view your pictures etc on the SONY Cyber-shot DSC-W350 ? it is really annoying to hear the beeping every time you...
I have a W560, but maybe it's the same on your camera. It was driving me insane as well. On my camera, I went to the menu, under Main Settings there was something called "Beep." It gave the options of "Shutter, High, Low, and Off." If I chose Shutter, then it keeps a shutter-like noise when you take a picture but turns off the annoying beep whenever you push any other button. I assume if you choose Off it will turn off all noises.
Hope that helps!
Jan 07, 2011 | Sony Cyber-shot® DSC-W50 Digital Camera
Nikon D80 shows err and no picture can be taken. shutter gives ussual sound as if taking picture. autofocus does not work
I have just experienced the same problem while on vacation - very frustrating! Luckily my wife had a D60 so we could continue shooting. I checked the troubleshooting section of the manual and it advises to try firing the shutter. This did not clear the problem and indicates a camera malfunction, so I am arranging for the camera to go to a Nikon Service centre. It's very annoying as the camera is only 20 months old and has not been used heavily.
Sep 03, 2010 | Nikon D80 Digital Camera with 18-135mm...
Shutter stays open. says turn off and on when
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;} If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
  1. Power off your camera.
  2. Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
  3. Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
  4. Power your camera on without the memory card installed.
  5. Take a picture.
    • If your camera takes a picture, re-install the memory card, and then go to Step 6.
    • If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
  1. Format the memory card in the camera, and then take another picture.
  2. Important: Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
    • If your camera does not take a picture with the formatted memory card installed, replace the memory card.
    • If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
Jul 25, 2010 | Samsung L77 Digital Camera
The viewer is "black". The camera takes pictures, goes through th motion, sound, but the picture is black, no image
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2010 | Canon PowerShot SD1000 Digital Camera
Black screen
Oct 06, 2009 | Canon PowerShot A510 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Samsung T809 Cellular Phone Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
