Question about Horizon Exercise & Fitness
Cannot change numbers on Horizon Series T95 treadmill control panel
Input buttons do not change speed, incline parameters
  • 16 Answers
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Posted on Apr 14, 2009
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Posted on Jun 03, 2009
SOURCE: My console does not allow me to change the
my treadmill is doing the same thing. the only buttons that work are the start; incline up. 4 incline; 8 incline; and 11 incline.
Posted on Oct 14, 2009
Testimonial: "He asked the right question."
maxtreadmill
  • 832 Answers
SOURCE: my smoothfitness 5.25 treadmill is stuck in the
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
Posted on Mar 11, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
Horizon T91 Treadmill - Key Pad Troubleshooting
correct. If the console is not responding or some buttons do but others don't the membrane needs replacement.
Apr 02, 2017 | Horizon T92 - Treadmill
Horizon treadmill model ls925t will not allow the grade to be adjusted. It is stuck at the highest grade
RUN THE SOFTWARE CALIBRATION. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Apr 02, 2013 | Horizon Exercise & Fitness
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
My horizon 4.1t treadmill will incline/decline but does not run. showing an e1 error. please help
1) Adjust the speed sensor, clean, and tight the connector very well
see the diagram
2) Lube the deck belt, by lack of maintenance,
3) Test the motor input voltage, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor,if there are the board is ffaulty.
RUN the software calibration for diagnose and troubleshooting.
May 09, 2012 | Exercise & Fitness
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel to reduce the incline.
Sep 21, 2010 | Horizon Fitness Merit Fitness 725T...
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
My console does not allow me to change the incline, speed, etc. The control panel does not acknowledge the buttons pushed. I've turned it off and on.
Sep 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Apr 18, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
20 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
