Question about Acer Office Equipment & Supplies
Projector lamp failure - Acer Office Equipment & Supplies
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: lamp failure
Lamp duty cycle is approx 2300 hours and you know how since long this projector is working with you.
Posted on Aug 22, 2008
  • 144 Answers
SOURCE: projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
Posted on May 08, 2010
INFOCUS IN102 PROJECTOR LIGHT BLINIKING
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Aug 02, 2017 | Cell Phones
Lamp of benQ projector switched off suddenly and failed to light again,but the power button is ON and the fan is working,so what are the causes and how to solve the problem?
Hi
It seems like the lamp has failed. The cause of this is because the lamp can only run a certain amount of Hours before it will fail completely. On some projector models you are able to view the expected fail date and on other there is a warning light on the projector itself indicating that the lamp has reached a certain amount of hours and failure is imminent. Replacing the lamp should solve your problem and is usually quite easy to do
Kind Regards,
Oct 23, 2013 | Sanyo PLC-400 projector lamp Projector...
I have a viewsonic pjd5111 when plugged in and try to turn on both the temp and lamp light glow orange, the projector tries to come on I can hear the fans come on but the projector lamp does not come on,...
Unfortunately, the PJD5111 is indicating that the lamp has overheated. If you wait 45 minutes for the projector to cool down and these lights still come on, then the unit has an internal failure. The failure may be in the temperature sensor or that circuit. If the projector is still under warranty or on a maintenance plan, contact the dealer.
I wish that I had better news for you.
Feb 22, 2018 | ViewSonic PJ551 Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Projector says lamp failure and picture has turned Yellow
May 06, 2010 | Hitachi EDX-3280 LCD Projector
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
Blue cloud in the middle of our Hitachi 62VS69A Screen. Lamp went out and after replacing it we now have a blue cloud in the middle of our screen. Is it a bad lamp or could it be more than that?
if it is an lcd projector, its possible the lamp blew due to fan failure and the lamp getting hot prior to failure may have been enough to burn the lcd's. If it is an lcd projector, that's most likely what has happened
Apr 27, 2009 | Office Equipment & Supplies
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Lamp failure
Aug 22, 2008 | Dell 3300MP Multimedia Projector
22 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
