Question about Maytag MAH2400 High Efficiency Front Load Washer
Dc68 02032a manuel washer
Clanking sound during draining cycle
5 Suggested Answers
SOURCE: Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Posted on Aug 29, 2007
Illeagle
  • 525 Answers
SOURCE: Maytag PAV2300 won't spin correctly
You may have an obstruction in the pump, a faulty belt, or a pump failure. If the washer is unable to remove the water as it spins, centrifugal force would cause water to exit over the top and onto the floor. As the washer spins, slowly at first, water is extracted via the pump running at full rpm. As the water level decreases, so does the weight of the load, so the tub will begin spinning faster. If the pump fails in its job to remove the water, the weight is more than the drive system can handle, The clutching action slows the rpm of the motor which, in turn causes the motor to automatically shut off on its thermal protector. After the motor sufficiently cools, the thermal protector closes and the motor resumes the cycle. If the problem does not resolve itself, the motor will continue to cycle off and on, which could lead to a motor failure. Also, rarely a clothing item may attempt to breach the top during such an episode, and cause a jamming of the inner and outer tub and even, subsequently make its way to the pump, so inspect there for foreign material.
Tip: If clothing is in the pump or stuck up by the tub collar, the cause is due to overloading the washer. Cutting back on load sizes will prevent this from happening in the future.
I have provided you with a link that will give exploded view diagrams and parts imagery with cost and shipping details.
http://www.repairclinic.com/0100_21.asp
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
  • 17 Answers
SOURCE: Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
Posted on May 23, 2009
SOURCE: maytag washer will not agitate during wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Above is a service manual this will show you how to troubleshoot and repair.
Posted on May 04, 2010
I don't know what my error code means and my washer won't start
I had the same problem, My issue was a small sock that was sucked into the drain tube at the bottom of the washer. The technician removed the bottom panal and drained (a lot) of water from the tubing, then the sock came out, it had been preventing the water from draining out. It didn't seem to be a difficult repair to do on your own
Dec 20, 2013 | YouTube Videos
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Suds Message and washer stops cycle with with F02 code and beeps
sounds as if you may have a problem wiht oyour drain pump"the little black thing onthe side of the drain screw" something might have gotten into it and damaged it causing the noise and now not pumping out effiently. as far aas "suds" this could berelated to your problem , for if soapy water not being drained youlll getthis condition, but i would check your detergent . You NEED to use an HE detergent(HE high efficency spefically designed for front l;oading machines)
Feb 16, 2009 | Whirlpool GHW9100L Front Load Washer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Clanking, sparking sound coming from washer
Need to know a little more info. Need to know if this noise starts when you first turn it on (during the fill up cycle), once the actual washer starts (wash cycle) or when it goes into spin cycle.
Jun 11, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag MAH2400 High Efficiency Front Load Washer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
