Question about Krups Food Processors
Krups ka902 scales not reading correctly
Press the zero button to reset the scales then put a known 500g weight into the mixing bowl and it reads something different. Put the same weight on top of where the blender goes and it reads correct +/- 10g
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Nov 24, 2017 | KitchenAid Food Processors
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
I just bought a new 3200xl magimix and it not working
I had this problem. I fixed it by turning the bowl to face the opposite way.
There is a little plastic button - the handle has to be over this.
Jun 11, 2012 | Magimix 3200 Food Processor
The robot coupe will stop working periodically during use. The reset button on the bottom pops out after it has been used for a short while. I run a kitchen and it can be very frustrating trying to get...
It is overheating, probably because it is being overworked. Some common problems are overloading the bowl, or forcing too much food into the hopper on top. Once it overheats, it will kick out again rather quickly the next time unless the motor has time to cool. If you are shredding cheese, slow down on the amount of cheese forced into the blade. If you are trying to mix heavy dough you are probably overloading the bowl as well. This machine can't handle over a pound of pizza dough without overheating. The reset button is there to keep from burning the motor out. If you continue to reset and force feed the machine, it will burn the motor out. Good luck, hope this helps.
Sep 11, 2010 | Robot Coupe R2U Ultra Food Processor
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Appears to be locked but won't turn on
Instructions only apply to Cuisinart DLC-2011 series:
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with lid lined up with work bowl handle.
Put pusher sleeve into lid's feed tube, with metal element facing the front of the food processor.
You should now be good to go.
-Tha Mp3 Doctor
Apr 16, 2008 | Cuisinart DLC-2011 PowerPrep Plus Food...
Food Processors Logo
35 people viewed this question
Top Krups Food Processors Experts
eyecam
Are you a Krups Food Processor Expert? Answer questions, earn points and help others
