Question about Metabo SBE750 1/2" 0 1,000/0 3,000 6.2 Amp Impact Drill W/Case
Metabo sbe 750 manual - Metabo SBE750 1/2" 0 1,000/0 3,000 6.2 Amp Impact Drill W/Case
2 Suggested Answers
  • 123 Answers
SOURCE: Metabo SBE 750 Have continuity through the trigger
IF you have continuity through the switch and the brushes look good then remove on brush and look at the commutator segments. There should be nice even gaps between each segment. If you have on that a goodbit wider than the others then your rotor is bad. If not then more than likley your stator is bad.
Posted on Aug 12, 2011
How do I load the drill bits in the keyles chuck of my Metabo impact drill Model SBE 561?
Keyless chucks work one of two ways
1: Simply turn the chuck by hand to loosen or tighten drill bit, once it grips the drill bit you will not be able to turn it anymore
2: Some keyless chucks operate by pulling the chuck back towards the body of the drill, placing the drill bit in and then releasing the chuck back to its original position
Sep 08, 2014 | Drills
Metaabo dill sbe 550 will work clockwise but makes a noise and will not work anticlockwise
stripped or broken teeth on the crown wheel on the reverse section in the gear box. Have it inspected at a metabo repair shop if you cannot do it your self. Check for spares availability
Jun 10, 2013 | Drills
Metabo BHE 22 manual wanted
you can ask to your metabo seller to give one to you
or here:http://www.metabo.us/E-Mail.3620.0.html
ask for a free pdf copy
Nov 01, 2012 | Metabo 600242420 BHE22 7/8" SDS-plus...
Aug 06, 2011 | Metabo Drills
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Manual somone?
Call Metabo (800-638-2264). They will send you one free of charge.
Sep 28, 2008 | Metabo MHE65 Sds Max Chipping Hammer
Metabo SBE750 1/2" 0 1,000/0 3,000 6.2 Amp Impact Drill W/Case Logo
Top Metabo Drills Experts
Colin Stickland
Colin Stickland
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Metabo Drill Expert? Answer questions, earn points and help others
