Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ge profile Refridge...
The lights are on, and you can hear a fan running...but all the food in the freezer is thawed out. and the fridge is warming.  When I try to move the temp gauge (digital) i can hear it beeping but i cannot see if its making the temp warmer or colder.
  • Jessicalk Oct 19, 2007
    it is very warm in the back when i pulled the fridge out from the wall.
  • Anonymous Feb 11, 2008
    When I went to my fridge tonight, I noticed the DE symbol was blinking. How can I get it to turn off? My freezer is defrosting and I think my fridge also.
I went through troubleshooting steps on the Internet and found my defrost timer was not working properly. It was located behind the plastic panel which is where your plastic temperature knobs are. There is a slot all the way to the right of the temperature knobs once you lift the plastic panel, and when you turn it clockwise it will eventually click and my refrigerator started cooling.
Posted on May 10, 2008
Check the cooling coils, and very likely they are full of dust preventing cooling.
I have an attachment I put on my vacuum cleaner to clean out these coils at least once per year.
Posted on Dec 06, 2007
    Problem Solver:
  • 8 Answers
Check if the outside walls and back are hot to warm,. if not warm posible low level gas, or commpressor not pumping gas around.
Posted on Oct 19, 2007
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Fridge is not cold and freezer is thawing all my frozen food , is compressor gone?
Check if fan in freezer is running as well as fan by the compressor and the compressor itself. Check for any frost buildup on evaporator cover in freezer.
Nov 17, 2011 | GE Refrigerators
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Profile fridge Model #PSC25MSTASS Wacky temps in Freezer for several weeks, so much so that ice will not stay frozen, so we just shut the ice maker off. Most of the other foods would stay frozen,...
Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Sep 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Energy Star Refridge...
brookid, first you want to start with the basics; door seals are good, light turning off with door closed, dispensor duct door closing all the way, condensor coils cleaned, evaporator fan and condensor fan are running. If you are satisfied that there are no problems here then you want to see if you have a heavy frost build-up on the back of the freezer panel. If you do, you have a defrost issue that usually involves the defrost heaters, main board or freezer thermistor. Tests will have to be made on the main board to determine these. If you don't have a frost build up, you need to check the airflow vents from the freezer to the refer compartment. I will attach a photo of a refrigerator with a defrost problem. Catriver...post back.
Sep 26, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
