Question about Sony KDF-E55A20 55 in. LCD Television
Crackling noise at turn on
We have a 55" Sony Wega TV and we started getting a curved purple line at the bottom of our screen a week or two ago. It starts about 12" in from the left and right sides and humps up like a sunrise would be. Then we started losing picture and a horizontal block of the picture would move up the screen and then it would correct itself. Today we tried to turn on the TV and it makes a horrible sound like the guts of the TV are being electricuted. What in the world could be causing this problem.
  • 285 Answers
Maybe you have a really, really bad cable.
What signal are you using when this happens?
If it happens with just one signal (normal tv, dvd player, PC), try replacing the corresponding cable.
If this happens with multiple signals, I would contact my manufacturer and request a new tv, because this one is broken.
I hope you can get a new tv,
Yannick.
Posted on May 20, 2009
I have a 55" Sony Wega HDTV rear projection television and it has developed purple pin size spots on the screen. It started with just one spot and quickly grew to hundreds of spots over a couple weeks....
You should do a regular cleaning maintenance to the air filter and exchange it regularly. Small dust particules may get into the internal projection module and those spots became visible.
Oct 06, 2013 | Sony Grand WEGA KF50WE610 50" Rear...
When I turn on grand WEGA KDF-55xs955 55 in. projection tv it does nothing but make a crackling noise from the left speaker. The screen stays black, I get no picture at all, and it also starts to smell...
Have you checked the lamp? I would start there if you haven't. Take the lamp out and look down in it to see if the filament is cracked or broken. That is definately what it sounds like. I have seen many of these at shop.
Jul 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Red Vertical bars cover the right 1/4 of the screen. They starting appearing sporadically several weeks ago and would go away, now they stay on the screen, regardless of video input ..
Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the TV requires service.
Jul 25, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have more and more tiny bright blue dots
hello it may be the light engine that's faulty
shaun
Sep 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Wega 42" LCD w/Bright Blue haze at bottom corner of screen
hello it sound like convergance may need setting go in to the menu click on convergance you should be able reset the picture
good luck
shaun
May 14, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega model # KV-36FS12 it doesn't work can u help me?
This is due to humidity in your area. Due to moisture content screen control section getting corrosion. cleanit and adjust the screen control to get the normal picture.
Sony KDF-E55A20 55 in. LCD Television Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
