Question about Xantrex Technology RS3000 Sine Wave Inverter / Charger
I have a rs2000 inverter/charger not charging batteries
buffalonyman
  • 1865 Answers
SOURCE: Our Inverter works but the battery charger seems
There is no way to guess what the problem is, we technicians use a multimeter to look at the electrical circuit values to determine the problem. The charging circuit could be bad, or the batteries could be shorted.
Posted on Nov 23, 2009
nitrospawn
  • 290 Answers
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Posted on Feb 26, 2010
nitrospawn
  • 290 Answers
SOURCE: HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Posted on Feb 27, 2010
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
Posted on May 21, 2010
SOURCE: Xantrex model rs2000. just purchased used. owner
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Posted on Dec 25, 2010
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter...
Dec 20, 2010 | Xantrex Technology Xantrex RS2000 Sine...
I have a problem w the auto Gen. start turning the Gen OFF once it has started it. The lowest voltage setting to turn it off is 14.0vdc the problem w this is it will never reach that voltage. So I set the...
Your experience matches my own. I think the only solution is to use a DC monitor such as the Victron unit which has an external relay. Hook up the relay contacts to the Temp in on the AGS, then set the Victron to trip the relay when the batteries are charged to whatever percent you decide, such as 80%. Use the DC volts to start the gen and percentage of charge to turn it off......
Nov 17, 2010 | Xantrex Technology Xantrex RS2000 Sine...
Inverting side working fine but charger is not
I had a similar problem at work yesterday.when your charger switches of it assumes that the battery is fully charged, while it is not.this is the solution , switch on you inverter machine and allow it to run, while it is running use a direct current "dc" multi meter a test the voltages of the batteries any one that drops like 3 volts below the normal voltage is bad. Change it and you will notice that the problem will stop. Note that when a battery is bad it takes little time to get it charged than when it is in a good condition .
May 26, 2010 | Xantrex Technology Xantrex Trace Series...
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
HEART 25 INVERTER
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
The batteries on my narrow boat ran low and the inverter appears to have cut out. We have recharged the batteries but there is still no power output. The inverter is live because there is a low power...
It's quite possible that you are charging your batteries with a "smart charger." The problem with some smart chargers is that when a battery is drained below a certain voltage, the charger assumes the battery is a lost cause and stops trying to charge it. You may have to get a cheap "dumb" charger to bring the batteries up to a reasonable voltage before turning things back over to the smart charger.
Dec 28, 2008 | Electronics - Others
Xantrex Technology RS3000 Sine Wave Inverter / Charger Logo
70 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
Jimmer_9
Level 1 Expert
richie46
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
