Question about LG Art Cool LA121CNP wall/window Air Conditioner
Front panel will not close when turning unit off (where the picture is)
When turning the unit off it doesn't close the screen it stays open
Press alt+ctr_del. and go to processes and turn off the process which one is hanged
Posted on May 20, 2009
Were is the reset button onwhirlpool model ler4634bq1
There is no "reset" button. If the light stays on it is almost certain your door switch is broken. The door switch turns the light on/off when the door is opened/closed, and likewise allows the dryer to turn on/off when the door is closed/opened. These switches do break and are relatively easy to change. First, ALWAYS DISCONNECT APPLIANCE FROM POWER; second, remove lint filter screen and unscrew the two phillips screws located on the dryer top next to the lint screen handle; third, using a putty knife release the top retention clips located at the front near each side in the gap between the top and front panels; fourth, swing the top up and back out of the way and remove the two 1/4" hex head screws located inside the cabinet on either side near the top that hold the front panel in place; fifth, disconnect the door switch wiring from the plug connection and lift the front panel up and away from the cabinet. Now you can replace the door switch and reassemble in reverse order.
Sep 12, 2014 | Dryers
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
The screen to my cellphone doesn't work.
sadly nothing lasts forever . might be time to bin it
Feb 28, 2017 | Samsung Trance SCH-u490 Cell Phone
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
Have a RCA flatscreen model # L40FHD41, blue power light comes on and stays solid but I don't get any picture or sound. Screen stays completely black as if it doesn't have any power at all.
Other than checking all the connections going to it for signal it is likely a shop repair.
The nature of these sets is someone must open and inspect them and check for voltages missing.
At that point it becomes a guessing game---try the boards (purchase them) and see if a bad board.
It is always possible the front screen unit or display has failed which is fatal cost wise.
You have to weigh the cost of repair, age of set and cost of replacement in this.
The only way anyone can KNOW which board is bad is to actually remove and replace it----most shops look at it and shoot you a high estimate.
let me know if you have questions.
Mar 14, 2012 | RCA L40FHD41 40. in HDTV
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a HP laserjet 4mv, i remove the fuser to replace it then i close the front cover of the printer now ready to put in the new one I realise I cant open the front cover cause the little lever that you...
Do not understand the problem. The front panel is held in with a hook on each side but both these hooks are ON (part of) the fuser unit. So if you have the fuser unit out the front panel should not stay up at all. Can you please describe in more detail?
Sep 15, 2010 | HP LaserJet 4mv Printer
Unit only has power for a few seconds
could be a couple of things..1. issue with your ground connection 2. ventilation
May 29, 2009 | Kenwood eXcelon KDC-X879 CD Player
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
CD player not powering up
You don't mention what model of Kenwood, but this is a common problem with all rotating front displays.
The replacement of these ribbon cables can be awkward, some have a tension system and the removal of the 'mask' front cover has to be heated with a hair dryer to release the double sided tape.
Only a Kenwood dealer could get the cable as they are not an accessory
Oct 14, 2007 | Audio Players & Recorders
LG Art Cool LA121CNP wall/window Air Conditioner Logo
123 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
