Question about Neff B1691 Single circotherm super Stainless Steel Electric Oven
Neff Oven - Grill Element (new) not heating to full temperature
I have a Neff B1432N2GB/05 which works perfectly except that the grill element gets warm, but never hot enough to actually grill something. I have just replaced the grill element with a new & original Neff spare part but the problem remains.
I suspect that it may be a problem with a temperature limiter or regulator, both of which I understand are fitted, but I do not know which it might be. Given that the fan oven works perfectly and maintains temperature, does the grill have it's own regulator/limiter or is it a shared component which is still working for the fan oven but defective on the grill?
I could just replace both but if I can isolate the component I can hopefully save a few pennies in the process?
Many thanks for any assistance.
SOURCE: new world tgo 70 grill
I have a TGO 70 for sale in Doncaster
Posted on Nov 02, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Posted on Nov 21, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
barkencoa
  • 3463 Answers
SOURCE: NEFF B1320 OVEN DOES NOT HEAT UP. POWER ON FAN WORKING
The only solution here is to replace the oven element. as this is the reason the oven is not heating.
This to be found at the rear of the oven compartment, behind a removeable cover.
This will solve the problem.
Merry Xmas.
Posted on Dec 25, 2009
  • 417 Answers
SOURCE: Hi our NEFF B1451 oven has stopped working
It is most likely that the heating element has failed but there is the outside possibility it could be a faulty oven temperature sensor.
Posted on Jan 19, 2010
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
Neff b1421n not heating up, grill and fan ok
breakers off ,,,back wall bottom center is a mounting plate 2 screws to take out the pull out wires and remove wires(careful not to let them slide back in)install new element...wires first the push back in place(no need to open back) don't forget breakers on now...you did it.... good for you.
Aug 25, 2009 | Neff B1421 Electric Single Oven
Oven not heating up! Fan works. Grill works OK. Don't know what model it is? It's stainless with black hideaway buttons. It's a built-in Neff single oven. We had just roasted a duck, everything was...
Hi, The main problem I find with this fault is the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven. Thanks.
Jun 15, 2009 | Neff B1641 Single circotherm super...
Oven problem
Check that the solar plus grill element is working properly by selecting full grill, the whole element should heat up, if only half element heats up , then you need to fit a new grill element complete.
If the grill element is o/k , then it is possible the top oven base element is faulty, to check that is working, put top oven on and after a few minutews feel the base of the top oven, and it should be hot to the touch if it is not, then the base element has probably failed , and you will need to fit a new one.
These are the possible reasons for it to heat up slowly.
Plz rate my solution.
Thanks.
Jan 25, 2009 | Ovens
Hi.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff B1691 Single circotherm super Stainless Steel Electric Oven Logo
306 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
