Question about Dirt Devil Vacuums
Dirt devil total pet compact blows dirt out and has no suction. All hoses have been cleaned out.
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Posted on Jul 30, 2008
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Posted on Sep 19, 2008
galati2k
  • 281 Answers
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
Posted on May 05, 2009
  • 294 Answers
SOURCE: No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on May 02, 2010
heatman101
  • 43501 Answers
SOURCE: vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on May 28, 2010
My dirt devil vigor cyclonic pet has no clogs I can find,belt is like new,still won't suction, all filters are clean.
Look for a clog of pet debris right at the intake to the container. It may not be visible unless the container is removed.
Sep 11, 2016 | Dirt Devil Vacuums
How do I change the belt on my Dirt Devil Total Pet Compact vacume?
LOOK AT PAGE 19... The pages are not in order as the manual comes folded up.
I hope this helps you.
http://dirtdevil.com/file/898/
Feb 18, 2015 | Dirt Devil Total Pet Upright Vacuum,...
How do you turn off the hose suction when using the floor vacuum?
Hi! There is no way to reduce the suction in the vacuum. The hose should be assembled on both ends when using the vacuum on floors. You can reduce the suction by raising the 5-level height adjustment. Hope this helps!
May 23, 2014 | Dirt Devil Total Pet Upright Vacuum,...
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
Dirt devil jaguar pet vacuum - no power goes to vacuum
I've literally disassembled the ENTIRE vacuum. I got it for a dollar at the local goodwill with the intent on converting it into a dust collector for my mini workshop. As others have said. The suction is abysmal. I don't think it could beat a dust vac. And that's with just the motor hooked to dirt collector. No brush, no belt, no carpet adjusting. Just a motor, dirt collector and hose. Zero suction. Removed the hose, zero suction. Remove the dirt collector, solid suction. Dunno if the dirt collector is missing a part, but I doubt that based on other replies. I'm guessing all the holes in the red tube of top chamber are the issue. But I can't easily access it. I think I may end up cutting it open to try plugging some holes or some other modifications. But this vac is garbage in its original configuration
May 22, 2011 | Dirt Devil Vacuums
Thehose has no suction
remove and clean the filter. you can use a air compressor to blow it out or use a brass wire brush and tap the filter on the table until it looks nice and clean,, this will return the suction to your vacume. also at the same time as you are cleaning the filter, check the hose for any blockage ( especially down by the floor sweeper where the hose kinda bends down into the unit ) -- when a filter is dirty and the suction is not that great, dirt loves to collect and compact in this spot,, use a wire coat hanger to fish out and clean any debris.
c...
Jan 05, 2011 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have a Dirt Devil Vision and when I put a clean canister back in place the suction at the bottom of the filter clogs up and very rarely go into the canister. Also where the air blows out of the motor, I...
yes your intake hose is clogged thats the clear hose you can see it on the bottom from the back.disconnect the upper hose from your intake hose and try to push a coat hanger through with the end of the coat hangers end bent till its rounded so you don't puncture the intake hose
Jan 05, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Vacuums Logo
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
