Question about Furniture
Seat bearings lose - Furniture
Why don't bearings and calipers install completely?
You didn't seat the bearing(s) or race(s) all the way. You didn't say what kind of vehicle, but whether it's FWD with a sealed bearing or front inner and outer bearing with seal, shouldn't matter. If you have a sealed style, maybe you didn't seat the wheel hub all the way.
Oct 17, 2015 | Cars & Trucks
I need new bearings for seat of body sculpture rowing machine br 3050
Remove the bearings and take them to your local Industrial Supply retailer, they should be able to cross reference and get you the ones you need.
Feb 24, 2015 | Exercise & Fitness
Rattling noise after changing the planetary gear
The housing has to be worn if the bearing has play. Try a little tape around the bearing, or some thin brass shim stock. Of course epoxy may be a solution, if applied around the i.d. of the bearing seat. A little shortning on the bearing will keep it from sticking to the epoxy.
May 25, 2014 | KitchenAid New Professional 5.5 QT...
Loose driver seat how to fix
check the bolts around the seat
fasten them as they may be lose
Aug 18, 2012 | Citroen Xsara Cars & Trucks
I have a old 1.1/2 ton sears floor jack model is 328.12001
dont think seals will be available ,where it lock down to stay up is a ball bearing in a seat and this is worn .
May 07, 2012 | Cars & Trucks
How do i get the driver side axle off?
Step by Step:
1. Remove tire
2. Remove cotter pin / lock bolt in lower ball joint
3. Remove Tie Rod End nut.
4. with a 32 mm socket removed large axle nut (air tools will most likely be required for this stage)
5. Seperate the tie rod end from knuckle
6. Seperate Lower Ball joint from knuckle
7. Pull knuckle back while pushing axle out of the bearing
8. Pull axle to the side so you have enough clearance to pull right out.
9. Pull axle out (will be stiff as there is a c-clip holding it into the transmission) take your time!. Sometimes a sticky axle can be freed from the transmission with some prying between axle and transmission.
10. Replace axle.(make sure axle is seated fully into the transmission)
11. Re install all nuts, and cotter pins.
12. Make sure you torque your axle nut to 90 ft lbs. (CRITICAL!!) - Too tight can cause premature bearing wear, Too lose and bearing could seperate, and possibly loose the tire while driving.
Mar 15, 2011 | 1998 Suzuki Esteem
Lumbar bladder loses air
you will need to take it to an upholsterer - have them remove the skin of the seat and install a new one - then put the seat back in.
Apr 01, 2010 | 1994 Ford Explorer Limited
Humm in car
Try moving the tire to a different position and see if the sound stays with the tire or stays in the right front. Does it do it when braking, accelerating, driving straight all the time? Also - if you get on a long straight stretch of road with no traffic - switch it to neutral and turn the engine off - REMEMBER - you will lose power steering and brakes with the engine off.
Jan 30, 2010 | 2000 Chevrolet Blazer
How do i change my struts help
  1. Remove the strut assembly.
    CAUTION Do not attempt to remove the coil spring from the strut without first compressing the coil spring with the appropriate tool.
  2. Install a suitable spring compressor to the coil spring and compress the spring until the spring tension is relieved from the spring seat.
  3. Remove the thrust bearing retainer nut.
  4. Remove the thrust bearing, spring seat and dust shield.
  5. Remove the coil spring from the strut.
  6. Remove the jounce bumper from the strut.
  7. Replace the coil spring or the strut as needed.
To install:
  1. Reinstall the jounce bumper to the strut.
  2. Position the coil spring to the strut.
  3. Compress the coil spring if removed from the spring compressor.
  4. Reinstall the dust shield, spring seat and thrust bearing.
  5. The coil spring must seat in the notch of the spring seat.
  6. Reinstall the thrust bearing retainer nut. Tighten the nut to 44 ft. lbs. (59 Nm).
  7. Install the strut assembly into the
you will need a strut spring compressor which cost about 50 bucks
Jan 20, 2010 | 2002 Mercury Cougar
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 31, 2009 | Exercise & Fitness
Furniture Logo
87 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
