Trying to connect up Sansui set top box - Model 0819 S/m 4013 to TV and VCR without a manual. Still not able to get ABC. It is an old TV (1992)- does that make a difference
Trying to connect up Sansui set top box - Model 0819 S/m 4013 to TV and VCR without a manual. Still not able to get ABC. It is an old TV (1992)- does that make a difference.
  • maudsleyjan5 May 20, 2009
    where would I get this from
  • 51 Answers
Yes it makes difference in picture quality. but u can do it with another connecter which has abc and old pin thread
Posted on May 20, 2009
Sansui sled2480. I am trying to use a cable splitter from my tv to my daughters Sansui. I have it hooked up, but she can only get the channel I'm watching. I had another tv set up the same way and she...
It seems you are using a set top box to access tv programs. I that case when a person changes the channel all the connected TVs will change. You should use extra set top box for multiple independent viewing.
Jul 19, 2011 | Sansui 19 in. LCD TV
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to program vcr to record digital channels?
Any VCR select to input source from where recording.
So select appropiate Euroscart or other AV connection.
Digital channel will be your digital cable set top box or sat receiver, DVD player, whatever. Very unlikely you use a digital capable set topbox to output to your VCR or TV with old fashioned RF coax cable where you have to tun in to cerain RF frequency under Channel 0 or so. So when in timer menu select that input source connection. Direct recording without timer select the source with remote. This solution applies to all brands
May 02, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
How do L set up the converter with a TV , a vcr and "Dish" satte
It sounds like you need a three way splitter.
You need to reverse the connections; the splitter has input and out. Hook exterior antenna, converter box, and satellite to the three side terminals (out). Hook the single sided terminal to VCR input. Connect the VCR out to the TV input. This configuration assumes that you will be using the VCR to record from all inputs. The TV has to be set to channel 3 to act as a monitor for your other devices.
Hope this solves your dilemma.
Feb 22, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sansui without remote
No. You will need the remote. Call the number on the set for an original. You could try your luck with a universal remote. Try a RCA brand. Good Luck!
Oct 18, 2008 | Sansui DTV2760 27" TV
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
