Question about Epson RX620 All-In-One InkJet Photo Printer
Printer says "Install ink cartridges correctly and then hit ok"
Yet I keep doing that, there are new ink tanks in there, granted they're not OEM but all my other epson printers use Non OEM ink tanks.However, it still doesn't work. What could be wrong?
Did I mention this is a refurbished printer.
  • Epson Master
  • 691 Answers
Try putting genuine ink it. If it still refuses to recognise the carts then it need to go back to Epson for a warranty repair. As an Epson eng 90% of the time, rubbish compatible cartridges are the source of such issues. They can even make the printer stop recognising genuine carts.
Do not mention to Epson that you used compatibles or they may refuse the warranty repair.
Posted on Oct 18, 2007
The following ink tank can not be recognized on mp620?
i would not refill my own cartridge tank with 3rd party if i were you. stick to OEM print carts only . Canon is very pickey when it comes to using OEM cartridges. call Canon direct to get new OEM cartridges 1-866-226-6634
Jan 03, 2012 | Canon PIXMA MP620 All-In-One InkJet...
Won't recognize ink cartridge
Try this. Insert only 5 only ink tank, without LM. See status monitor. All 5 ink status look gray? and LM look cross. Try to another ink tank left. Last, insert all ink tank. All ink tank not recognized (cross sign)? If yes, the problem probably is epprom.
Jun 09, 2009 | Epson Stylus Photo R390 InkJet Printer
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Changed black ink cartridge and now the carriage won't slide-just keeps hitting something that stops it right where the carriage goes to change ink cartridges. mrsgrdng8
It sound like you may not have gotten the cartridge installed correctly. Remove and re-install the cartridge and see of the problem persists. If it does remove that cartrigde and install the old one and check again. This will determine whether the problem is with the printer or the new cartridge
Apr 25, 2009 | HP Officejet 5610 All-In-One InkJet...
New cartridge and still shows ink low
Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink, even if it is not empty yet.
If the cleaning steps on your printer is still not fixing the color, try the very first tip on this page:
I have found that using warm water on the paper towel clears the prints up better.
Jan 25, 2009 | HP DeskJet 1280 InkJet Printer
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
3) Select [8] PRINTER TEST
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
5) Select 0. [INK COUNT].
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
(returning to the state of 3)),
and then press the [ON/OFF]
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
229 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
