Question about Toys
Vespa px 2006 both rear indicators will not work
  • 706 Answers
The electric connectors of the rear blinkers are on the front bottom hook of the side panels and need to be clean blank metal (sandpaper) and put in the hole very tightly - use also some WD-40 contact spray
Vespa px 2006 both rear indicators will not work - vespa-px-2006-both-rear-indicators-will-o4bn0faalxcoa4vjv5kzyzff-3-0.jpg
Posted on Nov 29, 2014
2 Suggested Answers
  • 561 Answers
SOURCE: vespa px lights do not work
check the connection of the bulb ensure itis fitted correctly also check fuses it maybe that the bulb for the lights has blown, it is common that the brake light is on a seperate fuse for safety.
Posted on Dec 02, 2009
How to decrease the exhaust sound of Vespa PX150
Hi, Saleh that all depends on your current muffler if it's a stock OEM muffler that is in excellent condition then you would have to seek the advice of a muffler expert to fabricate something for you but if it has rusted holes or has a broken baffle or you have an aftermarket performance muffler installed then a new OEM muffler would quiet down the offending noise..
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Vespa PX 150 exhaust question
Exhaust BGM PRO BigBox TOURING BBT Vespa PX80 PX125 PX150 Sprint GT GTR...
VESPA PX 150 USA Workshop Manual
PartsSchematicP PX PXE STELLA 125 150 200
VESPA 150 Operation And Maintenance
Apr 04, 2017 | 2005 Vespa PX 150
When applying the brakes on my vespa px the lights go out and the rear brake light doesn't work
That would indicate that you have a short to ground in the circuit, so that when you apply the brakes, you ground the system and the lights cut off. Check all of the wiring carefully, especially at the brake lever and make sure that when you move the lever, no wires are caught or moving.
Mar 07, 2015 | Vespa Motorcycles
Rear indicators not working
the electric connectors of the rear blinkers are on the front bottom of the side panels and need to be clean (sandpaper) and put in the hole very tightly - see photos 30893672-9af4-4248-8b2c-c66d3af0b101.jpg 42fbf355-7132-47a8-8c58-7edc7d4ba41e.jpg
Jan 03, 2014 | 2005 Vespa PX 125
Rear incadicater have stopped working on vespa px 125
The electric connectors of the rear blinkers are on the front bottom of the side panels and need to be clean blank metal (sandpaper) and put in the hole very tightly - use also some W-40 contact spray
-see photos
rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-0.jpg rear-incadicater-stopped-working-vespa-sxbikrkt5iu1vmjxkjitshw2-5-2.jpg
Jul 19, 2012 | 2005 Vespa PX 125
I have just bought a 1978 Vespa 125 px I can't get leaded petrol what can I use ?
All Vespa's old or new run without need of lead as your engine internals are lubricated by either the gear oil or 2 stroke oil.
Jul 18, 2012 | Peg Perego Vespa Scooter
Gears clunk when change on vespa px 125
don't worry -the clunk noise is typical when changing gears on a Vespa 125 PX
- it is due to a very old fashioned construction in the gearbox (1940ies) see pictures:
you have to get used to that or change to a newer automatic type Vespa....
May 22, 2012 | 2005 Vespa PX 125
How do i replace brake pads on vespa px 125
if you have experience as a mechanic you can do it by yourself, but otherwise it is better to have it done by a pro, as the brakes are a main safety item....
How to replace Vespa drum brakes NYC Scootering New York City scooter news...
replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-0.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-2.jpg replace-brake-pads-vespa-px-125-hrvlixid2vnvvtoada3i3rpn-5-5.jpg
Feb 23, 2012 | 2011 Vespa PX 125
My 2006 vespa px 150 scooter suddenly lost power to the back left turn signal. there is power to the switch but doesnt seem to have any to the left cowling. i checked and changed the bulb, it was fine. i...
Usually just a bad connection. Clean the side panel pin on the 'front' of the panel and the hole in the frame. Check also that your rear pin's rubber sleeve is in good condition.
Sep 25, 2010 | Peg Perego Vespa Scooter
My indicators on my vespa px 125 (1982) have stopped working, can u tell me waht i should check?
as for the rear indicators:
The electric connectors of the rear indicators are on the front bottom hook of the side panels and need to be clean blank metal (sandpaper) and put in the hole very tightly - use also some WD-40 contact spray - it's a common issue with the PX
indicators-vespa-px-125-1982-fy5fp1iqojzo1zmigdz00x1c-5-0.jpg indicators-vespa-px-125-1982-fy5fp1iqojzo1zmigdz00x1c-5-2.jpg
May 27, 2010 | Motorcycles
Vespa px lights do not work
Dec 02, 2009 | Peg Perego Vespa Scooter
Toys Logo
150 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
