Question about Lexmark X642e All-In-One Laser Printer
900.80 Service RIP Software
I think first it was showing "ERROR 342" (not shore about the 342), then (in another day) the above message.
no other details to give.
sorry for the english i´m not good at it, hope you can undertand.
tnx.
  • 3 Answers
This error can be resolved by clearing the print cue for that printer at the print server if its a network printer. If this is a local print just do the same at the computer, clear all documents that is in the cue for print and that should cover you:)
Posted on Jul 07, 2009
    Problem Solver:
  • 9 Answers
Install your printer driver again....
Posted on May 20, 2009
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
My Dell M5200 printer says 900 Service and RIP Software. I have restarted it several times and checked the menu - all looks o.k., but it won't print. It sounds like it is going to and then the above...
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
Nov 15, 2010 | Dell M5200n Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Lockups and 900.00 Service RIP software errors on C534N printers.
are these printers hooked to surge protectors? 900 rip error is a software communications error and can be caused by any pcb in the printer. any surge, lightning strike,ect can cause the nvram chips to have problems these errors can be intermitten or continuious depending on the damge to the nvram. have you tried isolating any of these to see if it still has the problem off the network?
Jul 15, 2009 | Lexmark C534N Printer
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
Mar 08, 2009 | Lexmark X422 All-In-One Laser Printer
Dell 3100cn error 007-342
you need to let the unit get tempered to you home environment before using the device being left in damp or warm areas can overwhelm the device if plugged straight in, leave it in your home for upto 3 hrs before using it you may need to reset it if the service code comes back up, hold the power button down on power plug inserted, for 10 seconds. but only do this when the printer is at your home humidity.
Jul 05, 2017 | Dell 3100cn Laser Printer
RE:canon Fax B120 ##342 error message
1.) press function then # u reach SERVICE MODE
2.) arrow right until TEST MODE confirm with Start / Enter (green button)
TEST MODE [1] - [8]
3.) press # ... u reach AMI MODE [1] - [*9]
4.) press 7 ... u reach FACULTY [1] - [6]
5.) press 6 ... .u reach LOST INK CHECK...confirm with green button...
u get [1] - [2]....
6.) press 2 u reach SET LOST INK CNT....confirm with green button...
u get LOST INK = 100 (in my case it was 100 ..this was the error..)
7.) press 0 (the digit zero..) confirm with green button...
8.) wait a few seconds....the unplug and reboot....
this worked in my case....
Oct 03, 2008 | Office Equipment & Supplies
Lexmark X642e All-In-One Laser Printer Logo
3,433 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
