Question about Vacuums
Pops open when bag still almost empty
Electrolux cannister vacuum (old) keeps popping open (shuts off) when the bag is not full. The problem started after cleaning some very dusty upolstered chairs.
    Sergeant:
  • 273 Answers
Try cleaning the filters if they are blocked then suction is lost and would appear like bag was full. hope this helps
Posted on May 20, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Cannister vacuum cleaner bag full sensor faulty.
I'm pretty sure it's not the power supply. If it were, you'd have more problems then the sensor. It sounds like you just need to replace the senor for the "bag full" light
Apr 19, 2017 | Electrolux Vacuums
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Have the cannister 6500 SP just changed all filters but when I start the vaccum it shuts itself back off and the full bag indicator light comes on?
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Jun 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Hello, My Electrolux Renaissance is about 12 years old. It worked great for years, but now it keeps turning itself off...about every 15 seconds or so. The bag was just changed recently, too. Is there...
Odds are you have an obstruction somewhere. Check all of the hoses and the power head to ensure that there is nothing blocking your airflow.
Also note that if it keeps popping the front bag door open, that's usually indicative of either the bag being full or not being installed properly, which can give you the same results, so try taking the bag out and popping it back in just to make sure everything is aligned correctly.
-R
Jul 31, 2008 | Electrolux Vacuums
I have Electrolux canister vac. The suction end pops open everytime it loads up.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=689886
Generic problem for all Vacuums
Posted by wmcox on Jun 20, 2008
I have Electrolux canister vac. The suction end pops open every time it loads up.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In the door there are vacuum lines that could be pinched or bent and are not letting air through to the bag, the system is designed that if the bag get to full or the air flow is restricted it will pop the door open and save the motor from burn out. This is repairable and nor to expensive and to check with the local vacuum cleaner dealer in your area or to call the Electrolux cust serv @ the factory for further information. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 20, 2008 | Vacuums
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Electrolux Oxygen3 model EL7001
If it is the top cover, the monitoring panel just pops off from the backside. You can use a thin knife or screwdriver and push on the locking clips, it then just hinges off of the front clips. After that is off you can see the two screws and after the top cover hinges off the actual door to the vac bags is attached to that cover it too hinges off.
Hope this helps
Mar 08, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
140 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
